#111 |
Dave, Chris,
From the pics it is evident that the Floor Stander Mar-kel70 III is doing duty. Some listening impressions for this build? - Zia |
#112 |
frugal-phile(tm)
It sounds pretty much like a Mar-Kel70. Maybe not capable of quite the dissappearing act as the primes or the trapezoid stand mounts. But easier to build, high WAF (Bernie took the pictured set to his brothers on the way to their owner, and wife said, we need 2 pair, 1 pr each up & downstairs).
Chris is thinking thru flat-paks on these. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#113 |
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#114 |
frugal-phile(tm)
#115 | |
KM |
#116 |
frugal-phile(tm)
I'dbe putting some fluff (or left over cotton felt scraps to at least a 75mm level at the extreme bottom between the baffle & the vent shelf.
dave.
#117 |
I'll do that, thanks Dave. Do you see any major benefit to putting some random height blocks behind the driver to break up any reflections that might make it back through the EL70 cone? I saw the treatment you whipped up at last year's DIY fest on another speaker.
KM |
#118 |
the figure on drawings I got from Dave stated between 45-106g of poly fiber batting in - I went for full felt lining and 100g on the pair currently on the bench
in my haste /hubris, I elected not to make the back panel removable and they're already buttoned up, so it's too late to change now - we'll see how they turn out
#119 | |
could make for an interesting jenga puzzle to combine something like that with front to back holey cabinet brace - I ran mine long enough to interlock with the port slot
#120 | |
frugal-phile(tm)
If the thot had occurred earlier the same thing could be done at the bottom. dave
| Thread Tools | Search this Thread |
| First build - miniOnken | matherp | Full Range | 6 | 3rd January 2010 04:58 PM |
| Clear picture picture of KSS-273B | eledora | Digital Source | 0 | 27th October 2007 01:10 PM |
| MiniOnken FR125 (pic) | MCH | Full Range | 7 | 6th November 2005 03:40 PM |
| Wee Need A Picture gallery | jleaman | Everything Else | 11 | 7th March 2003 01:33 AM |
