Go Back   Home > Forums > Commercial Sector > Vendor Forums > Planet 10 hifi
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 9th June 2011, 06:04 PM   #81
frugal-phile(tm)
planet10's Avatar
Originally Posted by CedMan View Post
... that's what i was wondering when I was building mine, I end up using some left over from my previous build ...
You want me to still send you the 2 missing pieces?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th June 2011, 06:06 PM   #82
CedMan is offline CedMan  Canada
No I'm good, thanks alot Dave.
dave
Old 9th June 2011, 06:06 PM   #83
frugal-phile(tm)
planet10's Avatar
Thick felt will do, but i can still send out pieces. Should fit in as letter mail. I'll just say it is thick, poor quality cotton paper
dave
Old 9th June 2011, 06:09 PM   #84
I'm ok, let me see what I can find, just wondering if you sourced it at like a
building supply place or hobby shop.
Old 9th June 2011, 06:13 PM   #85
frugal-phile(tm)
planet10's Avatar
I bought a 200 ft roll (800 ft^2) from the canadian distributor.
Bob at creative sound sells it in small quantities. You are unlikely to be able to source the exact same from any local source. One fellow pointed out the old Fords(?) are a good source of similar.
I don't want anyone to go out of their way because of my mistake.
dave
Old 9th June 2011, 06:49 PM   #86
zman01 is offline zman01  Bangladesh
Dave,
Does this help:
16 in. x 48 in. UltraTouch Denim Insulation Multi-Purpose Roll - 60301-16482 at The Home Depot
-Zia
Old 9th June 2011, 07:15 PM   #87
frugal-phile(tm)
planet10's Avatar
US only & 2" thick. Very good stuff to have on hand for things like microTowers, but of no use here.
dave
PS: Do i see in my crystal ball, one of Zia's buddies bring him a special "pillow"
Old 9th June 2011, 07:23 PM   #88
Dave, your crystal ball is working no doubt... fingers crossed, if things go according to plan, should have it within a couple of weeks.
Old 9th June 2011, 07:41 PM   #89
Default Quick question
Greetings,
Quick question. I'm still quite ignorant but am trying to learn as quickly about single drivers as possible.... Great site.
First post on this forum:
Do each speaker require a bit different design in enclosure or do these work for a wide range? In some quick conversations, the implication is that each driver require specific enclosure optimizations for that particular driver.
Would these work perfectly for the Mark 7 version 3 that is coming out? And what would bass extension be for 3rd order? (Pardon if this has been posted.)
Thanks,
UL
Old 9th June 2011, 07:56 PM   #90
frugal-phile(tm)
planet10's Avatar
Generally every driver needs to have a box designed for it. Some boxes are more tolerant then others and people will use similar spec drivers in those boxes (ie FE207e, Pioneer BOFU, and Hemp Acoustics FR8c often used in boxes designed for FE207e)
The FH3 is one of those very rare boxes that will accomodate an unreal range of drivers, tuning being accomplished with different damping schemes.
Mark is under strict "orders" from the diy community to try to maintain backward compatibility with old boxes as he relentlessly moves his drivers forward. I don't see it as likely that A7.3 won't work well in FH3. This rev is probably one of the least dramatic we have seen in awhile. Evolution instead of revolution (the multiForm cones being revolutionary, and the Matsubara-san spiders, a master let loose to do his best work, were first seen in metal on the A7)
dave
Frugel-Horn Mk3 Builds & Build Questions planet10 Full Range 814 10th May 2013 04:20 PM
Frugel-Horn Mk3 planet10 Full Range 1002 30th April 2013 04:52 PM
uFonken flat-paks planet10 Planet 10 hifi 15 11th May 2011 07:51 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
