Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 10th November 2015, 05:16 AM   #501
Ultralight is offline Ultralight  United States
Thank you Dave for your generous spirit.
Blessings,
UL
Old 29th April 2016, 12:44 PM   #502
ncdrawl is offline ncdrawl  United States
Originally Posted by planet10 View Post
$290/pr, less 10% if bought with a flat-pak.
You'll need to contact me via email. You should have that in your saved mail, but you can pick a valid one off any of the websites if you don't.
dave
pardon my ignorance, but I am finding the site(s) wherein you list the commercial flat paks/kits terribly difficult to navigate. I am trying to order a pair in kit form that includes everything I need(drivers and all), but from what I have seen so far on the commercial site it is unclear what is included. again it may be my dumb brain but need help! I want the 390 buck kit(what does it include and how much know-how is necessary to tackle this). thank you sir
Old 29th April 2016, 07:16 PM   #503
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Mk3 flat-paks
To order a flat-pak you email me, we'll make sure you get what you need… the site is information only (and like the shoemaker, it iften goes without shoes).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th June 2016, 12:01 AM   #504
zulk99 is offline zulk99  Bangladesh
Hi there sir I can't find your email, on the Planet 10 hifi page i get a blank page when I click you email, im interested in the flat pak.
International shipping available ? TIA.
@Planet10
Old 29th June 2016, 05:09 AM   #505
frugal-phile(tm)
planet10's Avatar
International shipping is available, but so far to pricey for anyone to jump.
There are a zillion links to my email address on my websites… which one to you clik to get a blank page?
dave
Old 29th June 2016, 07:17 AM   #506
Both in the Frugal-phile.com and planet10-HiFi, when I click mail us nothing happens and when I click open new tab selecting that its a blank page. maybe I am only having this issue.
How much would be the cheapest insured shipping to bangladesh
Old 29th June 2016, 09:15 AM   #507
frugal-phile(tm)
planet10's Avatar
What it should do is bring up an addressed email… it does for me. So it is likely a browser issue on your side.
I will get you a quote tomorrow, but you may also want to talk to Zia. He gets all sorts of enclosures made (he may have already done a set of FH3) and i am pretty sure he could get you a set all done up for what shipping would cost.
dave
Old 6th August 2016, 09:38 PM   #508
Niceonecyril is offline Niceonecyril  United Kingdom
planet10,
Daft question, but in the frugal horn design there are not 90 degree joints in the cabinet, rather bevel edges of about 85/95 degrees. Do the pieces in the flat pack incorporate these edges? Or, is that bit left to assembly through filing/sanding? I think I know the answer, but if so it seems too good to be true!
Also, are your nice assembled cabinets of light wood venereed or just the birch ply sanded/stained/laquered/whatevered to a finish?
Would be great to know thanks,
Niceonecyril
Old 7th August 2016, 01:17 AM   #509
JR_W is offline JR_W  United States
I've built speakers from the flat packs, and all the angles are cut for you - all you need is glue and clamps. The wood is birch ply, suitable for finishing. I did veneer the top and the front with birch just to hide the inevitable edges that were visible.
I had much more labor in the veneer and finish (just blonde shellac) than building the speaker boxes.
And all this science, I don't understand. It's just my job five days a week.
Old 7th August 2016, 06:27 PM   #510
frugal-phile(tm)
planet10's Avatar
All the pieces are cut to finished specification. Chris dry fits all the pieces and trim if needed (sheets of plywood differ a little in thickness)
You probably want to do a dry fit, and hit the corners with sand paper. In an ideal assembly one could so it with glue & masking tape (we recommend clamps).
The biggest issue (2/100) seems to be too much glue in the dado and then not being able to get the panel all the way into the dado leaving that piece high when putting the other side on.
Here is Chris doing a mock assembly which may give some insight: Frugel-Horn Mk3 Flat-Pak Mock Assembly Instructions
dave
Frugel-Horn Mk3 flat-paksHide this!Advertise here!
Frugel-Horn Mk3 Builds & Build Questions planet10 Full Range 1292 20th November 2017 07:22 PM
Frugel-Horn Mk3 planet10 Full Range 1602 2nd October 2017 08:18 AM
uFonken flat-paks planet10 Planet 10 hifi 20 23rd January 2015 08:35 AM
Copyright ©1999-2017 diyAudio
