Frugel-Horn Mk3 flat-paks - Page 41 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Planet 10 hifi
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 17th June 2013, 07:05 PM   #401
Originally Posted by angeloPB View Post
ok I guess I am going to try the Alpair 7. I would prefer the grey over copper. Honestly, I really like the look of treated drivers that were dyed different colors under the thread "it's not easy being green." And yes, I would be interested in driver baffle package.
Making your own baffle is easy.
Old 18th June 2013, 04:27 PM   #402
chrisb is offline chrisb  Canada
If you decide on the Alpair7 and the suprabaffle option from Dave, note that the driver through hole in existing baffle rebated for Fostex will need to be enlarged to prevent constriction that would occur with the extra layer of material.
The version of the kit that is shipped with SB option has a large rectangular hole cut in the full length front panel.
... so, not as easy at it sounds, this letting go thing
Old 18th June 2013, 09:12 PM   #403
Can't I just order a regular bafflle rebated for MA drivers? Seems that the suprabaffle over exisiting one that requires modding is less then ideal way to go.
Old 19th June 2013, 12:12 PM   #404
Default baffles
I can't see why not - I guess I assumed you wanted to use exiting parts in the kit.
Dave will likely see and respond to this query any time soon - if he's out of stock of spare A7 baffles, it'd have to wait 'til I return from vacation next week. The only question would be if you plan to use the Alpairs with extra basket ring or not. Both the diameter and depth of rebate is different between the two.
Old 19th June 2013, 06:22 PM   #405
frugal-phile(tm)
planet10's Avatar
Email me Angelo.
We have baffles for the A7 used with the bezel cover in the right material for your specific flat-pak, for use without the bezel cover we would need to scare up some baltic birch and make some new ones.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th June 2013, 03:28 PM   #406
Will do. I am totally cool with using the bezels.
Old 22nd June 2013, 10:11 AM   #407
Snip ... The only question would be if you plan to use the Alpairs with extra basket ring or not. Both the diameter and depth of rebate is different between the two.
Should be getting my kits from Toppsy tomorrow, which are cut for the Alpair7.3... Is this something I've overlooked? Or dependent on which generation of driver is used?
Not ordered my drivers yet because I've not been able to fully decide on a finish for the FH3's, and the copper or grey would suite different ones... Choices....
Paul
Listening with Gusto!
Old 23rd June 2013, 12:52 AM   #408
Paul
best answered by Colin
IIRC the 7.3s come with the baffles separate for the end user to choose, and they're pretty easy to install if Colin machined larger rebate
Old 23rd June 2013, 08:11 PM   #409
Now the proud owner of FH3 kits courtesy of Colin. Had the pleasure to chat with both him and his wife when they dropped the kits off... Ordered the grey Alpair7.3 minutes after they left to return home. Kits are cut for the 7's with baffle ring in place
Need to decide upon a finish, veneer, fully painted & lacquered, or a mix of the two... Either way, can't wait to here these babies sing!
Colin also mentioned the Alpair 10P & 12P for Classical music... But that's another project altogether.
Paul
Old 24th June 2013, 03:55 PM   #410
Originally Posted by planet10 View Post
Email me Angelo.
dave
I have not unpacked the box yet. But I am trying to weigh the feasibility of ordering new custom rebated baffles(the largest panel) vs modifying the Fostex one. Has anyone done this without using a supra baffle?
A. Looks like cleanest(and most expensive) option is just ordering rebated baffles.
B. Modify the Fostex baffle to fit the A7s, with or without supra baffle.
C. exchange/trade the Fostex for a MA one.
Frugel-Horn Mk3 planet10 Full Range 1562 14th February 2017 10:12 PM
Frugel-Horn Mk3 Builds & Build Questions planet10 Full Range 1255 31st January 2017 09:55 PM
uFonken flat-paks planet10 Planet 10 hifi 20 23rd January 2015 08:35 AM
Copyright 1999-2017 diyAudio
