Frugel-Horn Mk3 flat-paks - Page 40 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Planet 10 hifi
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 7th June 2013, 04:52 PM   #391
chrisb is offline chrisb  Canada
Originally Posted by BuildMeSomething View Post
Contacted Toppsy regarding kits, was recommended MarkAudio drivers above the Fostex ones...
Dependent upon how far these can be pushed into the corners [physically & critical placement], I have enough floor space to get a listening position of 2m, measured from the drivers.
Paul
Late to see this post - the FE126E is certainly not everyone's cuppa - that upper midrange "stridency" which some folks fatiguing is definitely real (but treatable) and any of the Mark Audio drivers that would fit the FH3 are smoother in that region - most notably the Alpair7.
Just be aware that Mark's drivers also need long break-ins, have BSC engineered into their FR and require different amounts of stuffing fill, and do not require the same proximity to corner loading as the Fostex- indeed may well be bass heavy if tight in a corner.
on hiatus
Old 11th June 2013, 08:38 AM   #392
Thanks for the info Understood that the MA drivers require 100hrs break-in. I'm going to implement full-band room treatment to help curtail all the usual junk. Having a driver with a fairly flat response & being able to tweak the bass from the FH3, might mean I can forgo any EQ'ing... Still thinking about adding a sub to get that bottom Octave in full.
Paul
Listening with Gusto!
Old 11th June 2013, 08:35 PM   #393
rmarkn is offline rmarkn  United States
Default Flat Pack for sale
If anyone might be interested, I listed my un-opened flat pack for sale in the swap meet section. Thanks, Mark
Frugel-horn Flat Pack for sale
Old 11th June 2013, 08:41 PM   #394
as I posted there, for which drivers?
on hiatus
Old 11th June 2013, 08:52 PM   #395
These cabinets would be for the 4" Fostex type drivers... Thanks
Old 15th June 2013, 05:38 AM   #396
OlavHaal's Avatar
Smile anyone seen this....
Hi all!
A very, very perfect soundcheck of one of Mark Audio Alpair7 in the Frugelhorn cabinet. Could such tiny drivers reproduce music better than it is described here? electricbeach Frugel3 Loudspeaker | Hifi Pig
Maybe I should build a pair? (WAF is one thing - besides my Alp12P and Alp10.2) - but temptations is big....
Best
Olav
Old 17th June 2013, 05:02 PM   #397
Great review^^ Olav. I am grabbing the flatpack listed on the swap meet, which has the baffles for the Fostex.
My questions:
Am I committed to the Fostex with that baffle or can a MA Alpair 7 fit with some "encouragement"?
I am kind of waivering between the FE126en or Alpair 7.
I have read the previous discussions. I was going to drive these with
the new version of the miniwatt SET or possibly my minitorri. My music taste jazz-straight ahead and fusion, indie rock, electronic lounge etc so not exactly chamber music. Just looking for low SPL but enganging presentation with emphasis on imaging and space over analytical accuracy.
if i go the 126en route, where can I find a pair that has been eNabled or treated?
Madisound is out of the grey Alpair 7s. Where can I score those?
Old 17th June 2013, 05:09 PM   #398
frugal-phile(tm)
planet10's Avatar
The rebate on the baffle would need to be redone. Or get converted to supraBaffle.
FF125wk would also fit.
Treated drivers, usually direct from me. We might bw able to provide new baffles if it gets that far.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th June 2013, 05:21 PM   #399
I have a pair of the 126en with some some EnABL treatment that are fully broken in. You can try them out first but based on your musical taste I would go for the Alpair 7s...much better IMO [at least in my BK-12M horns].
You are welcome to come by and have a listen.
Old 17th June 2013, 06:00 PM   #400
ok I guess I am going to try the Alpair 7. I would prefer the grey over copper. Honestly, I really like the look of treated drivers that were dyed different colors under the thread "it's not easy being green." And yes, I would be interested in driver baffle package.
Frugel-Horn Mk3 Builds & Build Questions planet10 Full Range 1271 6th April 2017 12:17 AM
Frugel-Horn Mk3 planet10 Full Range 1583 7th March 2017 10:34 AM
uFonken flat-paks planet10 Planet 10 hifi 20 23rd January 2015 07:35 AM
Copyright 1999-2017 diyAudio
