Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 2nd May 2013, 08:42 PM   #381
Sfwg is offline Sfwg  United States
Originally Posted by planet10 View Post
More than that now...
dave
That is just a darn shame!
Oh, well, it IS/WAS worth it!
By the way, finally got around to trying your Mod Podge and Ideal Duct Seal mods on the 8" woofer of the B&O Beovox S40.
Old 2nd May 2013, 08:47 PM   #382
scaleautoart is offline scaleautoart  United States
Originally Posted by Sfwg View Post
Welcome! I'm in central Florida and put together a Frugel-Horn flat pack last year. Fun project and nice set of loudspeakers.
Be warned! Postage is about $100.
Thanks!
I have been corresponding with Dave...and yes, it's about $130.00! He is a very patient man
Old 2nd May 2013, 08:51 PM   #383
Originally Posted by scaleautoart View Post
Thanks!
Dave and Chris are both fine examples of the best this hobby has to offer.
Old 2nd May 2013, 10:05 PM   #384
I just finished with the Damar and Mod Podge stage on a pair of 126 drivers. Just this alone smoothed them out a bit. Look forward to starting the dot patterns.
Once these are broken in and this is applied it really does transform the drivers. I do plan to do the Alpair 7 drivers when they are fully broken in.
Old 2nd May 2013, 10:33 PM   #385
BudP is offline BudP  United States
BudP's Avatar
Frugel-Horn Mk3 flat-paks
Just the dot pattern on the Alpairs please. Any more than that will be too much.
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 3rd May 2013, 04:46 AM   #386
Adam0 is offline Adam0  Belgium
Smile Don't make life too complicated
Originally Posted by nycello View Post
My main interest is speed and detail in the FH 3 As a musician (cello) I want to known what the artist is doing. Bass is nice, but I don't want to give up response or clarity, each of which are more important. I had been thinking about the Altair 7, but the low sensitivity seems like it would compromise clarity and force a more complicated amp. EdbSchiller's "bass augmented" (or a DIY alternative could be added later on). Any thoughts on a driver? I have a back wall but the corners are 3 feet away from each speaker. Listening position is 7 feet. Mostly classical, jazz, maybe antique rock.
Please don't worry about efficiency. The Alpair 7 is perfect for cello reproduction! It is by far the best driver in that instance. The efficiency is not at all a problem a good valve amplifier of 8 watts will be fine or even a 45 watt per channel silicon amp will be perfect. If you don't believe me check out Home Page and look up Valentini, it is a special build of the FHMK3 designed solely with reproducing the Cello in mind!
Old 3rd May 2013, 03:19 PM   #387
Bud
Thanks...understood
Old 13th May 2013, 05:34 PM   #388
BuildMeSomething is offline BuildMeSomething  United Kingdom
Hi, I'm interested in the FH 3 with Fostex FE126En drivers.
Only real question I have is; how suitable are the FH 3 for a small room [2.9m(L) x 3m(W) x 2.4m (H)] and a nearfield listening position [1 - 1.3m]? Prepared to do some room treatment & EQ tweaks if needed.
Thanks in advance...
Paul
Listening with Gusto!
Old 13th May 2013, 06:21 PM   #389
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
1-1.3m might well be somewhat close to get the bass from the horn to integrate with the utput from the front.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th May 2013, 08:38 PM   #390
Contacted Toppsy regarding kits, was recommended MarkAudio drivers above the Fostex ones...
Dependent upon how far these can be pushed into the corners [physically & critical placement], I have enough floor space to get a listening position of 2m, measured from the drivers.
Paul
Frugel-Horn Mk3 flat-paksHide this!Advertise here!
Frugel-Horn Mk3 planet10 Full Range 1603 3rd April 2018 01:31 PM
Frugel-Horn Mk3 Builds & Build Questions planet10 Full Range 1322 9th January 2018 08:06 PM
uFonken flat-paks planet10 Planet 10 hifi 20 23rd January 2015 07:35 AM
