#361 |
Dave,
Many of us are unable to actually experience an FH3 before committing time and money to a project, so we need to rely on opinions and data to guide us. Would you please publish FR graphs for the FH3 - maybe just a couple with the Fostex and Mark Audio drivers? I know this doesn't tell the whole story, but it would provide some standard measurement which we could interpret in light of the excellent discussion here. Thanks. |
#362 |
frugal-phile(tm)
I have no FR graphs of the FH3 at this time.
And as Ed Schilling says of any rear mouth horn, what do you wantit to look like, i'll move the mic (or speaker) a bit. The enclosure only has significant effect below ~300 Hz, where the room dominates. So above 300 Hz a FR of the driver in almost any enclosure will bemuch the same. This enclosure uses the room as part of the horn. Each room will be different. The only FR curves that will be anywhere near valid for you will be in your room. And since the room dominates we end up back to the Ed Schiling quote. Catch 22. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#363 |
Thanks for your reply. The standard practice is to place the microphone 1 meter from the driver on axis and then to take readings with 1 watt or 2.82 v at a distance of 1 meter. An anechoic chamber is not necessary, just a reasonably quiet listening room. Being Canadian myself, I understand your reluctance to do this outside.
#364 |
So you actually edited the post to which I responded after my reply. Interesting - like re-writing history.
#365 | |
frugal-phile(tm)
FR measures of a rear-mouth horn are a can of worms. An in-room FR response measure is only valid (roughly) above the frequency of the 1st reflection. A nearfield measure below that is next to useless in predicting the response in your room. Since the box does not affect the response significantly above about 300 Hz just look at any measured response. Mark's graphs for the MA drivers are very good. The factory ones for the Fostex are less reliable due to heavy smoothing. Any FR presented by a diyer with the usual candidate budget measuring mics are only good to about 10k if calibrated and less if not. A nearfield LF measurement of a sealed box is fairly straight forward. The math to sum a BR vent and the driver output is well worked out but subject to a greater margin of error. Trying to do that in a rear firing horn that uses the room to complete the horn is not at all worked out. And each room will be different. It ends up being a smulation. I could provide FR measures but peple would actually think they mean something when they are much more likely to be invalid for your room. dave
#366 | |
frugal-phile(tm)
dave
#367 |
frugal-phile(tm)
I should also add that an on-axis response, even if valid, is not very useful without off-axis results as well.
dave
#368 | |
frugal-phile(tm)
![]() dave
#369 |
Thanks for addressing my question. I guess I was looking for something like the modeled FR curves that are on the Frugal Horn Dalek and Metronome pages. BTW I am thinking about building a Metronome - the link to the plan seems to be down unless I am looking in the wrong place.
#370 | ||
frugal-phile(tm)
With MJK it is possible to specify part of a room with speaker placement and do a sim. The walls thou are perfectly stiff (not achievable in a real room). I do not know what simuated room these were in, but they are minimal damped. All the ripple above a couple hundered Hz will not be there in reality, and the LF will be modified by your room, placement and how much damping is actually used. Quote:
dave
| Thread Tools | Search this Thread |
| Frugel-Horn Mk3 Builds & Build Questions | planet10 | Full Range | 814 | 10th May 2013 04:20 PM |
| Frugel-Horn Mk3 | planet10 | Full Range | 1002 | 30th April 2013 04:52 PM |
| uFonken flat-paks | planet10 | Planet 10 hifi | 15 | 11th May 2011 07:51 AM |
