Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 12th November 2012, 06:45 PM   #341
Adam0 is offline Adam0  Belgium
Originally Posted by promitheus View Post
When do you think you will have these ready to ship?
1-2 weeks maximum
Old 14th November 2012, 03:02 PM   #342
CorradoBrit is offline CorradoBrit  United States
Originally Posted by planet10 View Post
In the same manner as Aiko is used here...
dave
I like the form factor of the Venom. And it would fit perfectly under my 96" wide wall mounted fixed screen. How well does this enclosure work with MA Alpairs and what is the largest driver that will work in that enclosure? Looks quite narrow.
Old 14th November 2012, 06:03 PM   #343
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Mk3 flat-paks
Each of these designs works with the driver it was designed for. Vampyr-V with FE103/FF105, Venom-V with FE127/FF125, Lotus with CHR70 (any), Coniston with EL70. No BVRs for the Alpairs. Old A10 is relatively close to new A10 box-wise so Jaguar would probably work (but i'd check with Scott), Kongo, Haruna, Kirishima for FE126En, FE166En, FE206En.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th January 2013, 02:30 AM   #344
nycello is offline nycello  United States
I am looking for a place to use Fostex 138ES speakers. Offhand, the FH3!looks like a good fit. Any thoughts?
Old 11th January 2013, 02:36 AM   #345
frugal-phile(tm)
planet10's Avatar
We have tested the FE138esr in FH3. Tremendous bass. The same can't be said about some of the rest of the range. If you can live with the issues the 138 has, then FH3 is a good choice.
dave
Old 11th January 2013, 05:31 AM   #346
My main interest is speed and detail in the FH 3 As a musician (cello) I want to known what the artist is doing. Bass is nice, but I don't want to give up response or clarity, each of which are more important. I had been thinking about the Altair 7, but the low sensitivity seems like it would compromise clarity and force a more complicated amp. EdbSchiller's "bass augmented" (or a DIY alternative could be added later on). Any thoughts on a driver? I have a back wall but the corners are 3 feet away from each speaker. Listening position is 7 feet. Mostly classical, jazz, maybe antique rock.
Old 11th January 2013, 06:25 AM   #347
zman01 is offline zman01  Bangladesh
He does have a stash of CHP70 gen 1.
dave
A good match for the FH3.
Old 11th January 2013, 06:44 AM   #348
frugal-phile(tm)
planet10's Avatar
Do you have FE138, or are you looking at getting a pair?
dave
Old 11th January 2013, 06:55 AM   #349
chrisb is offline chrisb
OK, if moderators can chastise members for errors with quote function in another thread, then please allow a couple of typo corrections along with some observations (or a public flogging for the preceding impudence)
It's Alpair, and I think you meant Ed Schilling, (both names with which I'm familiar) and bass augmenter. Of course I realize that sometimes sticky keyboards or hasting typing can explain an "F" instead of "G", "T" for "R", etc ( mr Planet10 probably holds the track record for those as well ) but even for a one finger typist, the T and P aren't that close together
OK, now that I got that outta my system (been a rough day), a couple of comments - I'm as much a fanboy of Fostex fullrangers as the next FR/DIYer, but unless you've actually heard the FE138ESR for yourself and enjoyed the experience, of the 2 I'd recommend the FE126En its sonic merits alone.
I've commented on the question of (rated) sensitivity of the Mark Audio drivers before - indeed it was rather a concern for "us" before the opportunity arose to hear them (in any enclosure), since after many years of playing with the 3-6" range of Fostex drivers (mostly the FE126/7 and 167) and often in conjunction with low powered tube amps ( 8W and under) , the lower number printed on Mark's spec sheets gave pause for thought "will my 3W 2A3 be enough?"
Well, I for one consider this to be one of the areas were the printed numbers don't tell the whole story: to cut to the chase, and to address the question of the FH3/A7.3 combo - it works very well indeed , doesn't need the same degree of boundary reinforcement to maximize the bass extension and weight as the FE126 would, and to many ears could be considered more neutral through the critical upper midrange than the Fostex.
That said, any FR driver of this size class can only benefit from support by competent bass augmentation, particularly, in my opinion, if the FR driver is actually HP filtered (say between 80 - 120 or higher ) thereby relieving the excursion demanded of it. I think you'll find the most noticeable improvement when adding separate woofers in this manner (stereo if XO any higher than 100 or so in a non HT system with mono blend of LF ) is a substantial increase in attainable SPL concurrent with increased midrange clarity, depth and image stability.
There are any number of candidates for midwoofers suitable to the task - IINM Ed uses one of the Silver Flutes in a fairly simple small box - but that may have changed since the last time I looked. In any case, one of the keys to seamless woofer integration is that the selected drivers have clean smooth response several octaves above the determined XO frequency.
That's enough from me for now
like my mind, this space intentionally blank
Old 11th January 2013, 07:17 AM   #350
frugal-phile(tm)
planet10's Avatar
In my defense, at the time i decided to take grade 11 math instead of grade 10 typing who knew we'd have computers even in our phones that would run circles around the very fastest computers of the day and that we's all have multiples (i have no smart phone, but my dumb phone is still faster, and i do have 7 computers i use regularily that would be classed as super computers 10 years ago)
The math has stood me in good stead,
dave
Frugel-Horn Mk3 flat-paksHide this!Advertise here!
Frugel-Horn Mk3 planet10 Full Range 1624 12th June 2018 08:46 PM
Frugel-Horn Mk3 Builds & Build Questions planet10 Full Range 1333 18th May 2018 09:48 PM
uFonken flat-paks planet10 Planet 10 hifi 20 23rd January 2015 07:35 AM
