Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 30th June 2011, 09:21 PM   #151
Phil Townsend is offline Phil Townsend  United States
Phil Townsend's Avatar
Default Dave and all I have a question about the plans
for the FH MK3.
Its about the choke point and measurements.
The plans call for the choke point to be 5 1/2" front the inside of the front baffle. But I am unclear as to the exact point of the measurement. The plans show the point directly across from the choke point. It looks like the measurement is perpendicular to the choke point and then the point across from it. The measurement is NOT referenced to the joint. Is this correct?
The other openings are referenced to the joints ie 2 3/4" and another 2 3/4"
the 5 1/2" opening is Not draw as the others are.
Granted the difference is small and may not matter...
Phil
Hey I got a Army wool blanket a surplus store for 20 bucks. ebay.
Phil
Santa Fe
Old 30th June 2011, 09:22 PM   #152
Default phils email
philji@mac.com
Phil
Santa Fe
Old 30th June 2011, 09:28 PM   #153
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Originally Posted by Phil Townsend View Post
philji @ mac. com
edit your post to look like this :
save your self from spam
Old 30th June 2011, 10:18 PM   #154
Default Never Mind
I restudied the drawings...
I got it...
Phil
Santa Fe
Old 2nd July 2011, 08:14 PM   #155
Default Caution
I want to tell you guys about an article in Fine Woodworking a few years ago.
They did a glue test.
The glue that tested the poorest were the foamie glues.
I too have found this to be the case. I will never use them. Good old Tight Bond was one of the best....
I just sayin...
You may not have the same results...
I'm just sayin...
Phil
Santa Fe
Old 2nd July 2011, 08:16 PM   #156
Default Glue Link
Link
How Strong Is Your Glue? - Fine Woodworking PDF Cover page
Phil
Santa Fe
Old 3rd July 2011, 04:39 PM   #157
Default Glue
Glue
ooops
Phil
Santa Fe
Old 8th July 2011, 07:39 PM   #158
wiatrob is offline wiatrob  United States
wiatrob's Avatar
Dave,
Finally picked up my flat packs from the post office this am. Wonderful packaging! Here's the sad news: due to an upcoming move to California I won't be able to build them.
So if anyone in the US is interested in a flatpack with enabled EL70n2's PM me, they'll be up in the swap meet soon. Sigh. Next Round!
Old 8th July 2011, 10:53 PM   #159
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Mk3 flat-paks
Bill,
They got their fast. Mailed them on Monday.
That is sad. They won't work in California? Sudden change of work?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th July 2011, 05:25 PM   #160
pchw is offline pchw  United States
Bill/Dave,
What else (material) do I need in addition to the flat pak?
Thanks!!
- Fred -
Frugel-Horn Mk3 flat-paksHide this!Advertise here!
Frugel-Horn Mk3 planet10 Full Range 1624 12th June 2018 08:46 PM
Frugel-Horn Mk3 Builds & Build Questions planet10 Full Range 1333 18th May 2018 09:48 PM
uFonken flat-paks planet10 Planet 10 hifi 20 23rd January 2015 07:35 AM
