Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 22nd August 2011, 10:00 PM   #131
chuyler1 is offline chuyler1  United States
chuyler1's Avatar
Originally Posted by shortwave View Post
Wow, those are nice. I am considering the pencils and thanks for the tip on the mitered joints as I am looking at the same ply you made yours out of and was thinking I was going to have to clue on a solid wood trim edge. What type of joint or means of securing them did you use? Thanks
Some build pics are a page or two back in this thread. Mitred joints for all the sides, then butt join for putting the front on. Wood glue was used all around, no nails or screws...except for the back panel which is removable.
You've got to be very careful with the plywood as it comes with a very thin veneer that can easily chip. I cut the pieces to the outer dimensions then mitered them afterward. Use scrap wood beforehand to make sure the table saw is set precisely. I had a few chips but I filled them with stainable wood putty. I could point out the spots to the average viewer, but standing a food a way you wouldn't notice. My woodworking skills on a scale of 1 to 10 are about a 6 or 7...but I know enough about hiding mistakes that the final product is passable.
Old 23rd August 2011, 09:18 AM   #132
wolkenlos is offline wolkenlos
Default Pensil 12 Austria
Greets from Austria!
Pensil 12
Old 23rd August 2011, 03:16 PM   #133
silverhairbp is offline silverhairbp  United States
Very nice. I particularly like the wood tone contrast. Are you using four spikes or three?
Old 23rd August 2011, 03:45 PM   #134
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Originally Posted by buzzforb View Post
F5 should have no problem. I am using AJ on 10.2 with plenty of power to spare.
Alpair 7 is the 4" fullrange driver with 20w nominal power. Are you sure they can handle the 25w / side.
Old 28th August 2011, 04:39 PM   #135
Originally Posted by chrisb View Post
chuyler - play with getting them as far out from the corners boundaries as much as can - with the driver's BSC compensation and the excellent performance of Scott's design, these will likely need far less "help" than you're used to.
I'd be vewy vewy careful with spikes on the carpet - after damaging both deep pile carpet (mine) and edge-grain solid fir floor ( Dave's) I've long since eschewed spikes altogether in favour of granite slabs on carpets and felt slider pads on vinyl/laminate and hardwood floors.
nice work, and now just enjoy the damned things
(This is probably a bit off-topic, but here we go anyway....)
Proper room placement can reinforce bass particularly in the very low regions. Allen Perkins has an interesting paper (re-penned by Joachim Gerhard in 2009) on speaker placement that I think applies very well to single-driver systems. I have not spoken with either Allen or Joachim regarding changes to Allen's original work.
http://www.immediasound.com/Speaker%20set-up%202009.pdf
This might not be the end-all / do-all for speaker set-up, but it might be worth a try or even a starting point for some. In my experimenting, the soundstage and imaging improved by moving away from the back wall a bit, but the boundary effect bass was reduced. It made for an interesting experiment in system performance tuning. YMMV.
Old 28th August 2011, 04:56 PM   #136
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Just because an amp can provide a certain level of power, does not mean it will ever have to do so. IF you want 20W nominal, try this variation.
F5 with 2SK2013/2SJ313
Old 28th August 2011, 05:22 PM   #137
I use a pair of Herron M-150 mono amps on a pair of bipole CAA FR125SRs (that's 150 watts on each speaker). It's not the amount of power that's available, it's how its applied and the frequency used. 5 watts at 500hz is a lot different than 2 watts at 20hz.
Old 28th August 2011, 11:09 PM   #138
That's CSS FR125SRs, not CAA. Sary abuot teh tyepo.
Old 31st August 2011, 01:24 AM   #139
markaudio is offline markaudio  Hong Kong
markaudio's Avatar
Hi Guys,
I've made a new thread re measurements as the topic is interesting. Keeping this thread mostly for "pics".
Please feel free to go to this thread to follow up on test experiments on Chuyler's project and measurement contributions:
http://www.diyaudio.com/forums/marka...derations.html
Please let me know if any member wishes to have their posts migrated.
Mark.
Old 1st September 2011, 06:47 PM   #140
In the Alpair 7 thread it is noted that driver height is important in the cabinet design. Would it then be unreasonable to expect a Pensil 10.2 cabinet with the same internal volume and vent dimensions to perform less successfully if it were taller but less deep?
The reason I ask is that, like to individual making comment on the Alpair 7 thread, I prefer a driver that is quite a bit higher than the various Pensil designs call for. My personal preference is for midrange drivers to be between ~ 40" / 1 meter and 50" / 1.25 meters above the floor.
Pensil Pics, lets show 'em!Hide this!Advertise here!
My Super Pensil 12.2p Build -With Pics! tlarwa Planet 10 hifi 12 12th January 2015 04:07 PM
Super Pensil Build with Pics zman01 Planet 10 hifi 38 9th July 2011 06:23 AM
why does my pics show as attachments? AudioGeek Forum Problems 8 6th July 2004 11:54 AM
Pics from T.H.E. Show in Las Vegas Timn8ter Multi-Way 7 13th January 2004 03:56 AM
pics from 2002 Stereophile show dorkus Everything Else 3 9th June 2002 08:19 AM
