Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 18th August 2011, 04:03 AM   #121
skeeter99 is offline skeeter99  United States
skeeter99's Avatar
Just moved into a townhouse after being relocated for work and got the setup mostly done. Still need to build a center channel when the design is done for an A12 or A10.2. I spread the speakers another 2" wider and 1" out on each side and its made a big difference and is throwing a better phantom center. Yes I know the drivers aren't even; the cabinet on the left is correct the one on the right is too high. Stupid person constructing them measured wrong OOPS!
Old 18th August 2011, 04:21 AM   #122
chrisb is offline chrisb
that'll disappear once the grilles are on
is the the final location? that would be helpful to know when it comes time to design the center channel enclosure
like my mind, this space intentionally blank
Old 18th August 2011, 04:27 AM   #123
skeeter99's Avatar
I'm going to rout out the wrong front panel and build a new one and glue it in. Shouldn't be TOO tough I hope! LOL!
You mean is the TV in the final location? No. I'm actually going to build a mount that brings the TV to the front and tilts it down a little. I'm hoping to make the center shallow enough to be able to mount below the TV. Could look kinda cool I think.
Scott
Old 22nd August 2011, 07:59 PM   #124
chuyler1 is offline chuyler1  United States
chuyler1's Avatar
Well, a week later, they are finished (almost). I still have to secure the bases and install carpet spikes...but I wasn't going to let that stop me from listening to them last night.
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Cabinets were built from 3/4" birch ply from Home Depot. Mitred joints were used to save on veneer. The only face that has veneer is the front, which is birch from Parts Express. 2 coats of Danish oil dark walnut stain. 2 coats of wipe-on poly. One coat of finishing wax and buffed to a semi-glossy finish.
I still don't have the polyfill right. They've got a tad too much bass on certain songs (not necessarily a bad thing) which is usually OK, but sometimes can be distracting. I'm also experimenting with room placement. They will be in the corners, but how far in, and how much toe I use is to be determined.
Old 22nd August 2011, 08:02 PM   #125
skeeter99's Avatar
WOW! Those are absolutely stunning! Top notch work, very nice!!
Old 22nd August 2011, 08:51 PM   #126
chuyler - play with getting them as far out from the corners boundaries as much as can - with the driver's BSC compensation and the excellent performance of Scott's design, these will likely need far less "help" than you're used to.
I'd be vewy vewy careful with spikes on the carpet - after damaging both deep pile carpet (mine) and edge-grain solid fir floor ( Dave's) I've long since eschewed spikes altogether in favour of granite slabs on carpets and felt slider pads on vinyl/laminate and hardwood floors.
nice work, and now just enjoy the damned things
Old 22nd August 2011, 08:54 PM   #127
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Anyone using there Pensil / Alpair 7 with an F5? I'm thinking of building a pair.
Old 22nd August 2011, 09:10 PM   #128
buzzforb is offline buzzforb  United States
buzzforb's Avatar
F5 should have no problem. I am using AJ on 10.2 with plenty of power to spare.
Old 22nd August 2011, 09:17 PM   #129
shortwave is offline shortwave
Wow, those are nice. I am considering the pencils and thanks for the tip on the mitered joints as I am looking at the same ply you made yours out of and was thinking I was going to have to clue on a solid wood trim edge. What type of joint or means of securing them did you use? Thanks
Old 22nd August 2011, 09:18 PM   #130
chuyler1's Avatar
I've noticed. They sounded best in the middle of the room...but sadly, they've got to be pushed back a little for the WAF.
Well the last set of speakers only moved when it was time to vacuum, and even then I usually just vacuumed around them. So once I get the right spot, they'll stay. The carpet came with the house and will be replaced eventually (we're just letting the pets destroy it first).
Pensil Pics, lets show 'em!Hide this!Advertise here!
My Super Pensil 12.2p Build -With Pics! tlarwa Planet 10 hifi 12 12th January 2015 04:07 PM
Super Pensil Build with Pics zman01 Planet 10 hifi 38 9th July 2011 06:23 AM
why does my pics show as attachments? AudioGeek Forum Problems 8 6th July 2004 11:54 AM
Pics from T.H.E. Show in Las Vegas Timn8ter Multi-Way 7 13th January 2004 03:56 AM
pics from 2002 Stereophile show dorkus Everything Else 3 9th June 2002 08:19 AM
