Illegitimate Son of Pensil - Alpair 10.2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Planet 10 hifi
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 29th January 2011, 01:14 PM   #1
buzzforb's Avatar
Default Illegitimate Son of Pensil - Alpair 10.2
Alpair 10.2 should be here Tuesday so it is time to start a build thread. As many on this forum do, I would like to put my signature on this project. Before starting, I have some questions to help guide me in the design. Hopefully with others help, I can create something unique. First question concerns the original Pensil design. Is this considered an MLTL? Would changing the box shape affect the rsponse as long as volume is kept consistent? Considering changing side view shape into something with curved line.
Can I break in the 10.2's using appr sized cardboard box, closed at first then cutting a hole to simulate BR?
Old 29th January 2011, 02:13 PM   #2
Scottmoose's Avatar
You could have asked me.
It's a specific alignment that's essentially a hybrid of different loads. The dimensions are functional, so if you alter them, you're on your own, as you will have moved away from the original design remit & behaviour.
Old 29th January 2011, 02:18 PM   #3
buzzforb's Avatar
I was hoping you would respond when I started this thread. I am ignorant and will rely heavily on yours and others advice. Of course it could't be simple. How would beveling the baffle affect response. I would assume it would help with baffle diffraction, but I am unsure of other subtleties.
Old 29th January 2011, 02:23 PM   #4
Scottmoose's Avatar
You can certainly bevel / round over the edges of the baffle. How much sonic difference it makes when wideband drivers (even those with relatively wide dispersion like the MA units) are employed is debatable, but it does look pretty.
Old 29th January 2011, 03:23 PM   #5
buzzforb's Avatar
My eventual hope is to use the 10.2 in a FAST type speaker. I am very interested in the Devore lineup, specifically his bass setup on the silverbacks. Do you or any one else have any ideas about what's going on in there. From the description, it seems that the two holes you see are ports.
Old 29th January 2011, 04:14 PM   #6
Scottmoose's Avatar
Link?
Old 29th January 2011, 09:25 PM   #7
buzzforb's Avatar
Interesting description of what is going on in the speaker in this review. I know the drivers are not connected to the outside box.
DeVore Fidelity Silverback Reference loudspeaker | Stereophile.com
Old 29th January 2011, 11:45 PM   #8
Scottmoose's Avatar
You mean low down on the back? Looks to be a fancy double-bass reflex to me, with each of the side-firing drivers being in its own chamber venting into a 2nd (also independent) lower chamber, which finally vents into the room.
Old 30th January 2011, 12:37 AM   #9
buzzforb's Avatar
You mean out the side?
Old 30th January 2011, 08:47 AM   #10
Scottmoose's Avatar
It doesn't have any side-firing vents; just the grills over the 8in bass units. The two vents are on the back of the cabinet, near the floor.
Driver/enclosure to complement Alpair 10.2 FR Pensil in a FAST system? southernoise Planet 10 hifi 24 7th February 2011 02:04 PM
Alpair 12 vs Alpair 10.2 and a little Fostex 166 germpod Full Range 4 28th January 2011 04:19 PM
PVC Alpair 6 Pensil guglielmope Planet 10 hifi 18 27th June 2010 08:07 AM
Alpair 10 wide bass driver and Alpair 10 Fullrange _henry_ Full Range 71 15th March 2009 12:37 PM
Copyright 1999-2017 diyAudio
