Illegitimate Son of Pensil - Alpair 10.2 - Page 7 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Planet 10 hifi
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 8th February 2011, 08:39 PM   #61
Scottmoose's Avatar
Similar to the Pencil 12.
It can do, although it's a bit sweeping to say it automatically will in all times & conditions. BW limiting will increase power handling & reduce AMD / FMD (doppler). How noticeable or otherwise depends on the box, system, room, material & how hard you're driving it.
Old 8th February 2011, 09:35 PM   #62
frugal-phile(tm)
planet10's Avatar
Originally Posted by buzzforb View Post
Is the functional bandwidth of the cabinet different than that of the driver?
Go back & reread post 29.
Let's consider that the energy to excite a resonance is inversly proportional to the 4th power of the frequency.
Let's assume that a typical MDF panel resonantes at 300 Hz. Now consider how much less likely a resonance is to be excited if we can push the panel resonance up to 1000 Hz.
(1/300^4)/(1/1000^4) = 123 times less likely. In a full range speaker one we have energy into the cabinet all the way up, but one can arbitrarily pick a point using the "less likely to get excited" criterion to decide where the functional bandwidth of the cabinet extends.
The chart shows relative likelihood of exciting a resonance at that frequency. Below ~300 Hz, the 4th order supposition breaks down
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th February 2011, 09:45 PM   #63
frugal-phile(tm)
planet10's Avatar
Originally Posted by Scottmoose View Post
Only insofar as there is a common belief that a dense material is automatically 'unresonant.'
Ignoring differences in damping qualities, given 2 panels of the same stiffness, the less dense one (ie the lighter one) is better given the criteria in my last post as resonant frequency is proportional to mass.
dave
Old 8th February 2011, 09:53 PM   #64
buzzforb's Avatar
Thank you Dave and Scott for the lessons. I know its gets repetitive. I am cutting the wood for the enclosures as I type. Hope to report back soon with picks, comments and 10 fingers.
Side note: The driver needs to be recessed about 3/8" leaving only 3/8". Do I need to provide more support for driver?
Old 8th February 2011, 10:07 PM   #65
frugal-phile(tm)
planet10's Avatar
We always add a driver brace, so the lack of infringement on the back-side of the driver is a bonus (we also champher the back side to open it up even more). Mounting the driver on the backside of an aluminum plate/subbaffle 3-4mm thick (and champhered on the front), would take that to extremes.
dave
Old 8th February 2011, 10:15 PM   #66
chrisb is offline chrisb  Canada
These do look so yummy when rebated for flush mounting, but the thick resin composite mounting flange does somewhat complicate things.
So yes, since I've been quite happy with the sonic results of a well braced 15mm BB ply cabinet, I usually laminate a small plate of 9mm material on the rear side of cut-outs. Of course one could always machine same in 3mm aluminum and tap for machine screws for the driver mount - but that'd be a bit obsessive, doncha think?
edit: now that's freaky - Dave's reply above posted while typing the above an answering the phone
cheers
... so, not as easy at it sounds, this letting go thing
Old 8th February 2011, 10:27 PM   #67
Scottmoose's Avatar
Agreed, per my previous posts. Give me a panel with a high MOE & decent bracing any day.
Old 8th February 2011, 10:59 PM   #68
Scott,
Do you have the modeled response for the 10.2 like you do for the 12? Also, do you agree with Dave that relieving the FR of its low end repsonsibilities will improve its mid and high frequencies?
Provided you truly relieve the heavy lifting with HP filter and direct amplification of the wide-band driver, you will also appreciate substantially reduced excursion, distortion and power compression, and increased dynamic headroom / max SPLs. This is as true with "full-range" drivers as with more conventional active multi-way systems with W/M/T.
The trick is deciding where to XO, and the number and location(s) of woofer(s). Note that while individual room dimensions/shape will determine the exact transition point, at frequencies often chosen for "subs" (why do I hate that word?) ,the optimal position of LF drivers may not necessary be common with those for the upper portion of bandwidth.
Old 9th February 2011, 12:14 AM   #69
frugal-phile(tm)
planet10's Avatar
Because boom, boom subs designed to appeal to the unsophisticated explosion loving HT crowd have given them a bad name. And because many "subwoofer" drivers are not extended enuff to integrate well.
dave
Old 9th February 2011, 12:35 AM   #70
buzzforb's Avatar
My eventual woofer addition will be in a FAST type speaker. My hope and current plan is to match the A10.2 with two CA22RNX woofers(I have one pair already). Pass Aleph J monos driving the A10.2 and mono F4's driving woofers. I don't think I could convince the wife about having subs placed strategically though-out the living area unless they could be built into current furniture. I am gearing more towards stereo over HT anyway.
Driver/enclosure to complement Alpair 10.2 FR Pensil in a FAST system? southernoise Planet 10 hifi 24 7th February 2011 02:04 PM
Alpair 12 vs Alpair 10.2 and a little Fostex 166 germpod Full Range 4 28th January 2011 04:19 PM
PVC Alpair 6 Pensil guglielmope Planet 10 hifi 18 27th June 2010 08:07 AM
Alpair 10 wide bass driver and Alpair 10 Fullrange _henry_ Full Range 71 15th March 2009 12:37 PM
Copyright 1999-2017 diyAudio
