Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi |
#81 | |
Hi Mark,
Sorry to forget to take photos of Pensil 10.2 cabs without the vents being blocked yesterday. I will ask Kenneth to take photos today. Thanks, Tony. Quote:
#82 |
Hi all,
Your experiences with the 10.2 have piqued my interest. The musical presentation of the driver - according to the descriptions in this thread - and FR are more to my liking than those of the 12. It also seems like an appropriate practical solution. I would like to run with a SET amp and am interested in the 300B that was mentioned. Can anyone share circuit basics (actually, mainly the driver details and coupling topology; for my purposes, the rest can be adequately interpolated). I guess I am trying to identify whether a 300B amplifier with good overload recovery (and perhaps additional power in A2) is necessary for adequate performance, or whether something like a pentode driving the 300B would suffice (for power). I guess I could simply give it a crack and if it does not work out, high-pass the amp (PLLXO) and run active (sub)woofers. Or sell and move on... Cheers, Raymond
“We must have concepts in order to function; they are not the problem. The problem is created when we believe they are the truth.” Charlotte Joko Beck |
#83 |
Hi!
My Alp10.2 in 18 liter ported has been running for low volume since wednesday - and I have now given some more power just to test carefully! AND the result is: not far off in soundstage from my friends MartinLogan/Wadia/Dynamic Precicion System - BUT with a lot more juice and touch to the sound. When I play Fred Eaglesmith/Car - it is like he`s in the room playing and you can actually feel the plucking on his guitar. And I only have a SS Harman/Kardon HK980. I think I have to build a Tube-Amplifier as my next project -when I have tuned my speaker-box till it`s best potensial! Good luck to all on the Alp-building wagon! Greatings to all Olav |
#84 |
Listen to a MinWatt N3 broken in there's no way a 2a3a can produce the bass that it does,none of the single ended tube amps do bass better than a single ended pentode ultra linear amp like the MiniWatt N3,Vaughn Audio Carina,Teconaudio i34,or the Sun Audio KT-88 single ended pentode ultra linear amp.All these amp gives thunderous well controllled fast bass,even with low efficient multi driver speakers even the nice Cayan's push-pulls i have on hand cant out finese them in the bass......
#85 |
300b's with good bass i would look into are the Dignity monoblocks sold by Mr. Pu at Monarchy Audio now they do bass very well no syrup spongy bass there.......
#86 |
A few ideas to scrutinize:
I could live with the Silbury footprint/weight if that horn type's "enhancement of dynamics" would allow for the 3watt Fi 2A3 amp to drive the 10.2's. I've never been a bass freak but "had" a Audio Note Conquest 300B SET amp which produced woolly uncontrolled bass on the same vintage 91db 2-way speakers the Fi 2A3 does a acceptable job with. The 3watt Fi has and can drive my old 88db EPI 100 (minimal 1 cap x-over, mid-bass rolls off on its own). Realistically thinking, a Para-Feed 300b SET like the Bottlehead Paramount should do it for the drive and bass/A10.2 (oh to figure out how to save for a BH kit). When i get a chance i'll A B compare the Fi 2A3 against the ~18watt Scott 222c, then the 25wpc Sonic Frontiers anthem 1 PP int amp using the EPI 100 speakers. The anthem produces solid bass provided impedance doesn't dip low. Before the Hiro it was driving Dynaudio speakers/flat 4ohm load. The Dynaudio's are now hooked up to the HT receiver, lol. I would hope to be able to drive the A10.2 with the 3watt Fi 2A3. I'd be satisfied even if they only work the smaller 11.5'x17' room as i still have 96db FE166ES-R drivers waiting for a scaled up 166 frugal horn design for recourse. I like what i'm reading and get the idea there's something special about the A10.2's. |
#87 | |
Btw, i have a 60watt HK880 from the late eighties, had a nice sound with good bass. Of course it couldn't compete with the Pass Aleph 3 i had on loan for a week but that was a $tereophile class A phenom at it's $$point. Nevertheless i think you'll like the tube amp. I couldn't go back to listening to the HK880 after hearing the tone of the tubed Scott 222c i was given that came from its org owners elderly wife wanting to see stuff from their attic appreciated again. |
#88 | |
I've tried Derek's N3 Miniwatt (3 watts) on the Pencils with 10.2's in them. Very surprised how well they worked. Then I tried the N3 on 14 litre BR's with 10.2's in them. Also surprisingly good but now quite as nice as Pencils. All the same, I'd suggest some experimentation with tube amps as my studio is a more open space so there's less damping compared to a living room. Be very interesting to know how well the Fi does on 10.2's. Bearing in mind your particular musical tastes, it looking like the 10.2's could be the driver of choice. Cheers Mark. |
#89 | |
#90 | |
We will know soon enough how it will sound. I had already ordered the parts to build ALeph J monoblocks. They will be biased to deliver nominal power to the 10.2's. If the Pensil blows me away, i may stop there(yeah right), otherwise i will be adding woofers to relieve low end. In my custom cardboard box they are sounding very nice at low levels. Too bad you don't live near NC, we could do a Firstwatt shootout. I cpicked the ALeph J because of the history of the Aleph breed and because it is considered a toobey SS amp. |
Thread | Thread Starter | Forum | Replies | Last Post |
Pensil 12 and B&W Matrix 802 | goneill | Planet 10 hifi | 65 | 26th April 2011 04:31 AM |
Driver/enclosure to complement Alpair 10.2 FR Pensil in a FAST system? | southernoise | Planet 10 hifi | 24 | 7th February 2011 01:04 PM |
Alpair 10 wide bass driver and Alpair 10 Fullrange | _henry_ | Full Range | 71 | 15th March 2009 11:37 AM |
Gainclone considerations (wrt chassis layout) | Selexus | Chip Amps | 3 | 29th December 2004 01:41 PM |
Speaker Workshop vs. other software WRT measurements | timsch75 | Multi-Way | 3 | 26th September 2004 01:11 AM |
New To Site? | Need Help? |
