Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 26th January 2011, 04:44 AM   #21
southernoise is offline southernoise  Singapore
Hi Olav,
He'll need an active crossover between the source and pre/power.
Active crossover
- Mid-High with volume control to pre/power amp - speakers
- Low with volume control to pre/power - speakers
Look here:
Linkwitz-Riley Electronic Crossover
XM1 Electronic Crossover Network
Old 26th January 2011, 05:18 AM   #22
planet10 is offline planet10  Canada
planet10's Avatar
Driver/enclosure to complement Alpair 10.2 FR Pensil in a FAST system?
I had a nice post done, lost it when i submitted it aganst forum maint. Let's try again.
Once you pull the links between pre & power you have a pre + 2 power amps. Then you connect an XO as shown in the diagram.
At least one of the power amps will need a gain control (the one that needs to be turned down to properly set the speaker levels). This can be in the power amp or the XO.
If you can get away with the limited capabilities of a PLLXO is is cheap & quite transparent. A PLLXO can't have level controls unless it is buffered -- which effectively makes it an active XO. Active XO can be more versatile,, some of the new DSP XOs very much so (but not without downsides).
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th January 2011, 10:20 AM   #23
OlavHaal is offline OlavHaal  Norway
OlavHaal's Avatar
Red face so it was...
Thanks Dave and Souternoise!!
Just spot on!
I had an inkling about just that solution - but there been too much water towards the see since I was occupied with amplifier/building - but someday one must - get behind the mule(Tom Waits) - and get better sound/relearn an old habit!
So I think my friend keep his old crossover - hides his old Nikko - run his Alpair Fullrange(as I recommended him)- or maybe a condensator at 120Hz later!
I will post lots of pics from my own building/prosess - Alp10.2 in a kind of Ported 18 liter next week: Maybe Dave will fancy some of those!
Thanks again!!
Old 26th January 2011, 12:20 PM   #24
norman bates is offline norman bates  United States
norman bates's Avatar
hiya bro.
Better soundstage ?
Sit closer to them if you want to run them wide open, or.
Place them on a coffee table directly in front of you (arms length away).
Try ambiophonics with them (place a divider between them, side by side directly in front of you).
If you want a deeper soundstage, you have to play with the spacing to the front wall.
As I am learning, it is all about what you listen to, how loud you listen, and how far you are from the speakers. People pull their speakers outside, they sound great, pull them inside, and they sound bad. Acoustics.
But very pretty in that box.
Old 7th February 2011, 01:04 PM   #25
OlavHaal's Avatar
Smile Hi all!
As stated earlier my friend wanted to try the Alpair10.2 in his Jamo-box. His Jamo was partly destroyed(crossover blown) - and the sound was not up to date. But the bass in those Jamos were still good(Push-Pull vented down to 23 HZ). So when I ordered mine drivers he set out his project - AND yesterday I heard it 1time!
And it is superb - the double bass is supporting the sound of the alpair to a degree I would not imagine. I must build an sdx7 support FAST myself!
But he is running those VERY revealing couple on the Advance/old Nikko combination you see there! And he run the Alpair in paralell with the Bass. But he has a 12db crossover he got from Ljudia - and that functions very good.
The Alpair is situated in the chamber where the old midband-driver was. It has a chambervolume that is between 5-6 liter(and sealed).
The tweeter which was where the foam is today. The foam that covers the hole - the hole is part if the two ports that the Jamo used for its Push/Pull.
And I think this elegant/simple solution has taken his music to a very high level. His speakers is MUCH more open - crisp and enjoyable than before. He still got that extremely capably bass - but one is more able to feel the attack of the strings of the bassguitar and feel the room the player is moving in!
Best to all - this was a good FAST
Driver/enclosure to complement Alpair 10.2 FR Pensil in a FAST system?Hide this!Advertise here!
ALPAIR 10 FR Focus on Listening experience elac310 Full Range 26 22nd October 2010 05:04 AM
PVC Alpair 6 Pensil guglielmope Planet 10 hifi 18 27th June 2010 07:07 AM
Center and Surrounds to Complement Alpair 10 Sides rajivs Full Range 4 26th April 2010 11:31 PM
Alpair 10 wide bass driver and Alpair 10 Fullrange _henry_ Full Range 71 15th March 2009 11:37 AM
