Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 7th January 2011, 03:05 AM   #31
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Super-Tysen
Yes. Front of sT will be Fonkenized.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th January 2011, 11:50 AM   #32
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Do TL's help smooth both the SPL response and the impedance response, beyond giving an improved bass response. Specifically why you would want to add one to the A7 portion of the Tysen considering the augmentaion of the bass. Will the bass section have its own TL somewhat like the Ariel speaker. How important is the angle on the front face of the driver in determining the improvement to baffle diffraction. Does it have to be a certain angle and how does this affect the response using larger or smaller angles. I am willing to be a guinee pig on this project assuming you tell me everything you know in the next of couple of days. Side note. My ceilings are 8ft. so i am unsure if the castle setup will work. I am also unwilling/unable to spend money on 4 woofers per speaker so maybe I can do a half-super tysen.
Old 7th January 2011, 09:21 PM   #33
frugal-phile(tm)
planet10's Avatar
Super-Tysen
The TLs are not for bass-extension. As a mid-TL they are damped opposite of a TL trying to achieve bass reinforcement (light behind the driver, getting progressively heaver as the terminus is approached, in the end trying to be aperiodic). The idea is to have a low pressure enclosure, with little or no reflection from the back of the driver, and a flattened impedance.
dave
Old 8th January 2011, 10:00 PM   #34
buzzforb's Avatar
What is your opinion of silver flute and hivi drivers
Old 9th January 2011, 01:14 AM   #35
frugal-phile(tm)
planet10's Avatar
Super-Tysen
I've not a lot of experience with the HiVi -- i do have 8 of their tweeters sitting here for a project.
I like the SilverFlute midbass. I've a whack of the 5 1/4" i've yet to play with. Eventually i'll try the larger ones.
dave
dave
Old 13th January 2011, 03:55 PM   #36
buzzforb's Avatar
Could the Tysen application be designed simlar to the ariel to take advantage of TL and MLTL characteristics.
Old 13th January 2011, 05:04 PM   #37
frugal-phile(tm)
planet10's Avatar
Super-Tysen
Tysen is a specific speaker, but a FAST can be made with any FR as a mid/tweeter, and any bass driver that will reach up beyond where you want to XO it. The style of box(es) you use is wide open.
dave
Old 13th January 2011, 05:29 PM   #38
buzzforb's Avatar
I came across a thread the other day where you spoke of the range of the male human voice going down as far as 100Hz. Is it wise to try to cross above or below this. Will extending the Alpair this low affect its ability to handle mids and highs.
Old 13th January 2011, 07:03 PM   #39
frugal-phile(tm)
planet10's Avatar
Super-Tysen
Male voice can reach down to 80 Hz.
If your mid-tweeter can handle the dynamics & upper bass "punch" required, going to 60-80 Hz would be a goal if male voices were the consideration. One has to compromise between max levels, dynamics, low XO point.
With the A7s in sTysen i think 100-200 hz is going to work.
Toole's work on bass in rooms would have mains 80Hz up, multiple mono woofers under that.
I am sure people will be, or already are using Alpair 10/12 like that. Lots of other candidates too.
dave
Old 13th January 2011, 08:57 PM   #40
buzzforb's Avatar
While we have discussed the A7 to this point, it would seem that the A10 is better suited for low XO. Do you agree with this? Would double A7's accomplish similar results? In your original design, you have a side firing woofer placed high up and just down from the Mid/tweeter to help with phase alignment issues. In my personal situation, i will have furniture(Ent.C) to the inside of the speaker and on the outside as well(open design bookshelf). Will it be better to have forward facing woofer to help eliminate room interaction. Firing into 4pi space XO low, is this as important. It seems I remember that room interaction/gain is important down low.
Super-TysenHide this!Advertise here!
A thread for Tysen and variations on FAST planet10 Full Range 253 27th July 2017 01:42 AM
audio nirvana super 10 or super 12 tonytex Full Range 11 4th September 2011 11:55 PM
Tysen Variation FE167E with CSS SDX7 ljfont Full Range 37 27th July 2010 04:46 PM
Cheap Version of the famous Tysen speaker. chris661 Full Range 108 10th November 2009 05:09 PM
FS: SUPER CD PRO KIT with SUPER SHOCKPROOF bbp Swap Meet 5 17th April 2009 06:09 AM
