CHR70x example projects (lots of pictures, not much text) - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Planet 10 hifi
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 5th April 2012, 07:43 PM   #21
frugal-phile(tm)
planet10's Avatar
Originally Posted by chrisb View Post
I'm not sure if Dave has posted the drawings for the Alpair7 dMar-Ken7a Centre, or if it's part of a subscription plan set.(my copy is dated Mar 1/2011, so it could be obsolete anyway) The format is the same as for the CHR, but the dimensions are different - so I wouldn't start making sawdust 'til you confirm that.
I don'y know if i have posted an A7.3 centre yet (one would need to check thru the FH3 thread). It is part of the program to have a centre to go with A7.3 Frugel-Horn Mk3s so if i haven't it will be a free for non-commercial use plan. There are more mutations (including custom ones to order) in the paid planset.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th April 2012, 10:21 PM   #22
chrisb is offline chrisb  Canada
dave
FWIW, the plan for centre for Alpair7 ( ie. not G3) that I built is attached
I don't have the most recent plan set at hand but would imagine the revisions for 7.3 to be relatively minor details regarding the slots.
The significant factor is the overall increase in dimensions vs those for the CHR70 - particularly the height which was left off the drawing but I've penciled on my as-built drawing as 152mm internal ( i.e. 12mm taller)
even if you don't tightly nest the holey brace to magnet, it's definitely worth the effort for coupling of the 3 long panels, and the ends could certainly be thicker and profiled with chamfer or round-over
http://p10hifi.net/FAL/downloads/dMa...reA-070311.pdf
... so, not as easy at it sounds, this letting go thing
Old 6th April 2012, 02:18 PM   #23
plund is offline plund  United States
Chris, Thanks for attaching the A7 Center plan. I can make that work for the 7.3.
Pete
Old 6th April 2012, 08:48 PM   #24
frugal-phile(tm)
planet10's Avatar
The plan for the A7.3
http://p10hifi.net/FAL/downloads/dMa...lan-060412.pdf
dave
Old 31st March 2014, 01:02 PM   #25
Default Alpair 7 or CHR70
Hello,
I made an amplifier with LM1875 (bridged - 50Wrms stereo) and a separate tube preamplifier. I think they are done pretty good. Now I am looking for drivers to make a good HiFi system.
Somehow I landed on fullrangers, especially those from Markaudio.
Now I could not decide between Alpair 7.3 an CHR 70v3. Could someone please tell me what exactly would I benefit from the alpair 7.3 over the CHR's? I europe alpair's cost 100 more. I have read a lot on this dilemma, but nothing have satisfied me so far.
Is there a significant difference in sound reproduction?
I listen to all kind of music, pop, rock, classical, blues... and..sometimes even house music in on. I have a room of 20m^2 and I mostly play music on moderate volumes.
Best regards from Slovenia.
Old 1st April 2014, 10:39 PM   #26
In short, I'd say that regardless of differences might be seen in whatever measurements you care to look at, the Alpairs deliver a large degree of several subjective qualities for which I'm not sure metrics have been agreed upon. "Finesse" , subtlety and articulation of low level detail (microdynamics) and a greater sense of depth /spaciousness of sound stage would be the buzzwords at the top of my list to describe the differences.
Old 1st April 2014, 11:21 PM   #27
frugal-phile(tm)
planet10's Avatar
Originally Posted by lukaursic View Post
In europe alpair's cost 100 more.
I'd say that is a worthwhile investment.
dave
Old 3rd September 2014, 09:57 AM   #28
Hello,
I have chosen the Alpair 7 gen 3 and they really satisfy my needs. The cabinets I made are Slim Classic GR dMar-Ken7.3 2v02, rear ported, made of solid oak wood.
Boards are glued together from smaller peaces of wood and the wood itself is about 30 years old. So I suppose there shouldn't be any risk of cracking.
Cabinets are not yet varnished. However, I am considering damping at the moment. I have some 25mm sonofil as described in construction plan, but what else do you recommend?
Do I have to use Bondum 800 or even Bitumex due to solid wood characteristics?
Old 3rd September 2014, 06:56 PM   #29
I think Dave's plans for the dMarKen would specify lining all internal panels with 1/2" Ultratouch denim felt "or equivalent", and perhaps adjusting with a minor amount of loose dacron fibre fill after driver's suspension fully broken in - i.e minimum of 200 hrs.
Bernie Foucher has built numerous pairs of all sizes of enclosures with solid wood, following this same practice.
I personally avoid mass loading or "viscous damping" of cabinet walls - but that is certainly an area of animated discussion, so don't be surprised to find very strong opinions voiced in all directions.
Old 3rd September 2014, 07:36 PM   #30
frugal-phile(tm)
planet10's Avatar
Adding mass without increasing stiffness, and lowers panel Q, bith taking the box quality backwards,''They also decrease the internal volume which would require a change in tuning.
So avoid it.
25mm sonofil can be considered as an approx substitute for 12mm ultratouch felt.
dave
Pictures and circuits of my DIY class D and other projects. classd_fromru Class D 97 23rd January 2017 03:39 PM
lots and lots of broken Vifa D26NC55 tweeters! gripracer Swap Meet 0 3rd October 2010 11:11 PM
DIY projects with pictures and measurements Phil Olson Multi-Way 11 12th September 2007 05:49 PM
Griffin Audio turntable and system (lots of pictures) Greg3333 Analogue Source 2 12th June 2006 01:33 PM
For people who like seeing pictures of other peoples "projects" SkinnyBoy Everything Else 48 6th January 2003 12:38 AM
Copyright 1999-2017 diyAudio
