Go Back   Home > Forums > Commercial Sector > Vendor Forums > Planet 10 hifi
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 4th April 2011, 08:04 AM   #21
frugal-phile(tm)
planet10's Avatar
Default Neo-fone Pair
SOLD
1 pair of DIY Hifi Supply Neo-fone wide range drivers.
These were cracked out of their boxes, spent some time on the break-in bench, got auditioned in an open baffle at VI diyFEST 2 or 3 years ago, and have been sitting since.
Not quite new condition, they have been soldered and mounted with screws to a baffle. $60/pr
Here is the data and plan set that i did up for Brian.
Matching data attached. Critical efficiency is very close.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th May 2011, 10:29 PM   #22
frugal-phile(tm)
planet10's Avatar
A pair (not a matched pair, but the critical efficiency parameter is within the 1/4 dB i allow so could be used as a pair) $130/pr
Sold.
Singles & Neophones still available.
Old 18th June 2011, 10:11 PM   #23
frugal-phile(tm)
planet10's Avatar
2 singles $55 each, or $50 each if you buy both
Sold.
Old 16th December 2011, 02:29 AM   #24
mor2bz is offline mor2bz  United States
Default ping dave
I have made new cabs for my Dynaco a25 woofers only to find that one
is bad. Have you another? I used tweeters from Radioshack/Realistic
MC-500 only to find that one of them was bad. Incredible how they sounded even with 2 bad drivers. Would you have a replacement,
or some vintage alnicos of the right efficiency (86 db?)? maybe fostex fe83 or 87? I would like to use 1st order highpass without resistors or lpads.
thanks david sundby sundbyd2@gmail.com 970-223-3908
Old 16th December 2011, 03:02 AM   #25
frugal-phile(tm)
planet10's Avatar
No i don't. Barry might have one,but i haven't seen him formonths.
What does that tweeter look like?
You'd be fundemently changing the nature of the speaker, do it right you'd likely be making things even better.
Given you are in the US, i'd say grab a pait of FF85wk, and cut 2 pieces of 4" PVC pipe that are the exact inside depth of the speaker, wedge & glue them behind the tweeter hole and go from there.
dave
Old 16th December 2011, 03:34 PM   #26
thanks Dave
I looked at the new 85 and 83. I think the 85 is more nearly the right efficiency
but the 83 looks smoother on top. below 4000 cps the 85 is much smoother but
I do not need that region. maybe the 83 and an lpad IS the way to go.
Old 21st December 2011, 07:52 PM   #27
OleBull is offline OleBull  Norway
Hi Dave,
Do you still have the Neofone pair for sale? I would use them as fullrange "test speakers" in rather small enclosures (10-13 litres) with small tube amps (3 watts or more). Hence, they should be easy to drive, have both some bass and resolution capabilities, but most of all they should convey music. Max sound pressure is not important.
Are there any other drivers that you rather would recommend for my application, still below USD 100 a pair?
Finally, a brief description of Neofone performance in OB would be appreciated.
Thanks!
Old 22nd December 2011, 09:55 PM   #28
frugal-phile(tm)
planet10's Avatar
OleBull.
Yes, i still have them.
It ws a long timeago we used them OB, they were fine, like almost 100% of other FRs they would need helper woofer on the bottom. They were also designed to have a cap coupled super-tweeter on the top, althou i found they weren't missing much. The bat-eared might disagree with me.
dave
Old 5th January 2012, 06:11 PM   #29
Hi Dave,
I am still keen on the Neofone pair. Seems you have disabled PM's, what is the best way to contact you?
Old 5th January 2012, 07:44 PM   #30
frugal-phile(tm)
planet10's Avatar
Send me an email Ole. Thru the pull down under my moniker or off any of my websites.
dave
anyone get/analyze (stock Fostex) FE206En? freddi Full Range 24 8th April 2010 06:00 PM
car audio: i like my stock speaker better??? kslim Car Audio 5 16th August 2009 03:00 AM
Uk Diyers Wilmslow now stock fostex khush Full Range 1 2nd March 2005 06:18 PM
Left overs...speakers hrclab Swap Meet 6 7th November 2004 08:09 AM
Page generated in 0.12435 seconds (76.42% PHP - 23.58% MySQL) with 11 queries
