Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 19th March 2018, 12:16 PM   #241
silasmellor is offline silasmellor  Denmark
It's not easy being green (apologies to Kermit)
Those lemon yellows are currently in my house waiting for boxes, can't wait to hear them. The color was partly out of concern for WAF, since my significant other chose a nice yellow couch for our flat. Naturally, her response to those drivers was very favorable Good job Dave!
Old 14th May 2018, 02:35 AM   #242
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Dayton PS220, black with white.
Old 14th May 2018, 02:36 AM   #243
frugal-phile(tm)
planet10's Avatar
Fostex FF165wKeN, yellowish/orange with white
Old 20th May 2018, 09:15 AM   #244
tubemax is offline tubemax  Netherlands
Hi Dave,
The last picture must be Fostex FF165WK or some new driver from Alpair line...
Old 20th May 2018, 09:18 AM   #245
frugal-phile(tm)
planet10's Avatar
Not thinking while i was talking. I am working on another pair for him, another colour — he is going to run 2 in parallel with a small SET.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th May 2018, 09:26 AM   #246
OK, it happens... btw, regarding Fostex FF165WK, do they have enough high's to be a real full range - let's say in a near field listening position, not more than 1,5 meter away?
One more question, what enclosures are available as paid plan-set for FF165WK?
Old 20th May 2018, 09:41 AM   #247
frugal-phile(tm)
planet10's Avatar
The FF165wk goes up far enuff for most people. AFAIK none of the ones i’ve done are being used with a tweeter.
For near field i’d personally pick something a bit smaller.
FF165wk plans (that are drawn) are a bit basic as yet, but almost any Alpair 10p plan can be adapted so more can be done quickly. I always look at a bew one as an opportunity to flesh out the planset. There is always more to do.
It's not easy being green (apologies to Kermit)-ff165wk-plan-list-png
I am working on a double high, double driver version of the Fonken165TT for the fellow with the quad of FF165 and will also drawn up the Twin Frugel-Horn XL (Frugel-Horn XXL?).
There will be a skinnier CFS, and 2 sizes of Classic Golden Ratio. A smaller trapezoid, and wider ones. And rectangular versions. At least.
dave
Old 20th May 2018, 10:01 AM   #248
Thanks Dave!
I can see a lot of R&D going on into this designs, I'll try to listen first to the stock FF125WK & FF165WK before making decision!
Last year I had built one full-range speaker set with Dayton Audio smallest driver PS-95 and it was good sounding driver even with some bass but because of small surface area didn't have any real impact, not enough even for near-field listening...
So this time I would like to try something with Fostex FF125WK or FF165WK in a simpler enclosure like dFonken125 or something similar for 165Wk if it exists ( like a slanted floor-stand box I've seen somewhere on DIYAudio - don't know the name ).
Old 20th May 2018, 10:05 AM   #249
frugal-phile(tm)
planet10's Avatar
That floorstander os called the Compact Floorstander. Stretching the standmount till it mets the ground gives a compact footprint. Wide one is drawn, skinny one is easier to do.
dave
Old 1st June 2018, 02:08 AM   #250
frugal-phile(tm)
planet10's Avatar
Fostex FF165wKeN, burgandy with white (colour added was bright red). Will be used with the FF165wKeN in post 243 to make a Twin Fonken165TT.
Click the image to open in full size.]
It's not easy being green (apologies to Kermit)Hide this!Advertise here!
Capless Parafeed (with apologies to SY) dsavitsk Tubes / Valves 9 30th November 2008 06:41 PM
My apologies to this forum for my post BHTX Everything Else 6 19th December 2007 08:54 PM
Apologies if this has been asked before. kevindoshea Solid State 1 5th May 2006 03:07 PM
Apologies to anyone who has sent me emails Andy G Multi-Way 0 18th October 2004 06:57 AM
apologies lod Introductions 6 30th January 2002 12:58 AM
