Go Back   Home > Forums > > >
Planet 10 hifi Home of the Frugal-phile™ - Planet 10 HiFi
Old 6th September 2010, 09:49 PM   #11
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Specific objectives?
Simple enclosure, easy to tailor to various rooms / systems, relatively flat impedance & a reasonably balanced response down to ~60Hz without requiring compensation circuitry in the vast majority of cases (there will always be some that need adjustments -that's just life. Mostly not though).
By that I mean, is there a suggested compensation network (like the original pensil)?
As in the taller Pencil Mark designed for the CHR? No. Most users should not require any Eq on the Pencils in practice. There are several threads on the Pencil 12; what applies to that basically applies to the Pencils for the smaller drivers.
Old 7th September 2010, 08:56 AM   #12
jonners is offline jonners  United Kingdom
jonners's Avatar
I recently bought a pair of CHP-70 drivers and I'm wondering if the taller Pensil 70 design for the CHR-70 can be adapted to suit the paper driver?
Old 7th September 2010, 04:46 PM   #13
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Pensil Series for Mark Audio Drivers
Here is the Pensil design for the CHP-70. http://p10hifi.net/tlinespeakers/FAL...map-180710.pdf
The original Pensil should be considered superceded,
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th September 2010, 10:18 PM   #14
jonners's Avatar
Thanks, Dave.
And would the Frugel-horn Mk.3 be an OK alternative for the CHP-70?
Old 7th September 2010, 10:31 PM   #15
frugal-phile(tm)
planet10's Avatar
Thanks, Dave.
I'd have to look at the data, but i'd guess it would be a suitable candidate.
dave
Old 10th September 2010, 05:25 PM   #16
Musik007 is offline Musik007  Hong Kong
Musik007's Avatar
Hi dave,
Is it good to add a tweeter onto the PensilP70?
Thanks,
Tony.
Originally Posted by planet10 View Post
Here is the Pensil design for the CHP-70. http://homepage.mac.com/tlinespeaker...map-180710.pdf
dave
Old 10th September 2010, 08:00 PM   #17
frugal-phile(tm)
planet10's Avatar
I've only seen pictures of the CHP-70, so i can't speak from experience.
dave
Old 15th January 2011, 02:11 PM   #18
cdurocher is offline cdurocher  Canada
Default Pensil-7 newbie questions
Hello,
I'm embarking on my first DIY project and after reading about the FH and tons of other designs, I've settled on the Pensil series of designs for the Markaudio drivers based on:
a) good reviews
b) good looking response graphs
c) build simplicity
d) lots of guys saying that similar looking designs were popular with their wives :-)
I do have a couple of pedestrian questions about this design as well as speaker building in general though.
1) How should the removable rear panel of the cabinet attach to the cleats that are there in the design? Are metal screws okay? Is there a better way? I might be missing how "cleats" work, if they work in any particular way at all.
2) General question... Is it best to have a terminal plate for any reason or can you simply mount binding posts directly on the wood of the cabinet?
3) If you did install a terminal plate, is any one location on the cabinet better than any other location? I guess the rear panel is not such a good idea if it is going to be removable but I'm just wondering about the effect on the acoustics internally to the cabinet. In an effort to hide the terminals as best as possible, would it be okay to put the speakers on a set of rubber feet and put the terminals at the bottom or is that really stupid?
4) In this design, does the location of the stuffing matter? I do intend to play around with the stuffing to get the best sound, but I'm wondering if there are any guidelines on this.
5) I don't want to cut any corners... So I'm wondering if there is *any* benefit to including an internal brace on the Pensil-7 design... Or would I be wasting my time?
Thanks a million!
Colin
Old 15th January 2011, 03:03 PM   #19
Okay, disregard my previous post... I see that most of these questions are answered in another post specifically on the pensil-7. My bad!
Old 15th January 2011, 05:03 PM   #20
frugal-phile(tm)
planet10's Avatar
Colin,
If you are not cutting any corners than add braces. We have found that the brace front to back that couples the driver to the back particularily beneficial for downward dynamic range. And with a removable back, it gives an additional place to attach the back.
An example is shown in one of the Pensil12 drwings i believe.
dave
Pensil Series for Mark Audio DriversHide this!Advertise here!
Small MLTL for Mark Audio Alpair 6 Drivers Jim Griffin Full Range 31 27th June 2016 08:21 PM
Drivers for Sale -Accuton, Newform, Dayton, and Mark Audio Digi Swap Meet 16 13th June 2011 07:18 AM
Mark Audio Alpair For First Build? d3ll Full Range 10 17th December 2009 07:11 PM
Mark Audio Drivers are on Sale!! mdikovics Full Range 24 7th July 2009 06:11 PM
Copyright ©1999-2017 diyAudio
