| Planars & Exotics ESL's, planars, and alternative technologies |
I've got a stack of neo8's for a line array, and was planning to stick a raven tweeter in the middle of them to handle 7K+.
But given the raven's limited verical dispersion, I was thinking about using 2 (cheaper) neo3 tweeters oriented @ 90 degrees. Would there be any combing effects if I can get these within an inch of each other? Thanks. |
#2 |
Have you read Jim Griffin's line array paper?
While the B&G's have limited vertical dispersion, they cover the horizontal cylindrical dispersion super. Zapfe rated the cheaper neo3's as better than any of the good domes that he compared them to, and way above the other ribbons and planars he measured. The key to vertical dispersion is in placing them on top of each other. Use at least a 35 inch line which will cover seated position listening to about someone who is 5'10 inches high. Putting one turned in the middle will not help. The interference of the sound streams will probably cause comb filter distortion that you WOULD NOT have had otherwise. You could use Dayton ND20FA domes if you cut the flanges. Two 33 inch lines will cost you ABOUT $210. I've done this, and its great, but I have to qualify that my system uses a Rane electronic crossover 24 db/octave L-R slope, and is Tri-amped, so comparisons without these electronics are not really valid. Zarathu calipso@epix.net |
#3 |
thanks Zarathu, I'll check that out.
Wouldn't a pair of dome tweeters also have this problem as well? i.e. isn't there some point at which sound from them will interfere in the same that from the ribbons will? |
| Theory in Dunlavys & vertical dispersion.. | Virtalahde | Multi-Way | 15 | 4th May 2010 06:13 PM |
| Remedy for ribbons' limited vertical dispersion?? | rick57 | Multi-Way | 18 | 23rd February 2007 10:52 PM |
| speaker dispersion | malcom_xavior | Car Audio | 2 | 14th December 2004 10:23 PM |
| Two Ribbon tweeters to improve horizontal dispersion? | goldyrathore | Multi-Way | 15 | 31st May 2004 09:10 PM |
| Baffle width vs dispersion | Vg | Multi-Way | 5 | 13th October 2003 07:34 PM |
| Page generated in 0.07558 seconds (73.58% PHP - 26.42% MySQL) with 10 queries |
