Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 10th April 2007, 10:06 PM   #11
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Originally posted by maudio
The fact that toroids have so few layers also accounts for their good frequency response, small winding height = less leakage.
Interesting. I thought the better HF response of toroids was down to the better magnetic path of the core - no sharp bends or changes in permeability to cause leakage, and therefore leakage inductance. Thoughts?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 11th April 2007, 10:18 AM   #12
maudio is offline maudio  Netherlands
That has little to do with it.
Leakage is mostly caused by the fact that the different windings never share all magnetic field lines, there are always some lines that don't go through all windings and so magnetic coupling is never 100%.
This is simply caused by the physical arrangement of the windings. They can never be all in exactly the same physical plane.
The thinner the layer of combined windings is the better. Since having few layers also reduces capacitance there is a double benefit for high frequency response.
A common way to reduce leakage is to interleave the primary and secondary in several layers. But the price for that is higher internal capacitances, which reduces the positive effect on high freq response.
In fact it's possible to calculate a pretty good estimate of what leakage for a given transformer will be, based on the arrangement of the windings and their sizes. Have a look at the RDH4, there is a whole chapter on the subject.
Old 11th April 2007, 12:17 PM   #13
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Originally posted by ak_47_boy
[B............Two 120V primary 6V secondary transformers work good, that will give you a 40:1 step up............. You can run the 6V side in parelell to get a lower independence also. ............ [/B]
Originally posted by DSP_Geek
This is not the safest suggestion I've ever seen here. The transformer insulation is rated at 120 V, perhaps three times that to cover overvoltages, but 3 KV? At that point it needs better isolation than you're likely to get from a power toroid.
Find another way.
The easiest way to find out if the insulation will take the voltage is to try it !!!
Anyone have 2 transformers - 240/60v and 240/6v ??
That should give 2.4Kv on the output.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 11th April 2007, 03:23 PM   #14
Brian Beck's Avatar
You can try it of course. But what works today might not work tomorrow. If the insulation materials pick up moisture and airborne contaminants, there can be an aging effect resulting in degradation of voltage stand-off. Also, a brief voltage peak might cause no breakdown, but sustained voltages could "punch through". Finally, once leakage starts, carbon tracking and dust attraction can make it worse and worse.
Brian
Woollett Electrostatic Tweeters 316a Planars & Exotics 11 11th August 2008 03:08 PM
Powering up/down Amp ptah Solid State 14 27th February 2008 06:54 PM
eqt not powering up! marko Car Audio 9 22nd August 2006 11:37 PM
Using electrostatic CRT's Simpleton Parts 1 22nd June 2005 10:08 PM
Powering an amp from just + and -? CryingDragon Solid State 11 22nd November 2002 09:04 PM
Page generated in 0.10230 seconds (77.62% PHP - 22.38% MySQL) with 11 queries
