Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 23rd September 2007, 07:16 AM   #21
Calvin is offline Calvin  Germany
Calvin's Avatar
You don´t take the insulation into account! The insulation is not only there physically but electrically too. You can see the effect clearly -as Cpacity already mentioned- in the efficiency of a panel. Look at the epsilon-r-values of the insulator. The higher the value the better the efficiency, because less signal voltage is lost within the insulator (keyword: capacitive voltage divider). So to a certain extend the larger spacing between the insulated wires is made up by the insulation itself. If You simulate wire stators with CAD-progs like FEMM You can see that the insulation supplies for a quite uniform field within the gap between stator and membrane, even when the soacing between the wires is quite large (as e.g. in Audiostatics).
Thats just one important reason why Nylon as well as PVC and PU are quite well usable as stator insulation (higher epsilon-r-value compared to other plastics)
jauu
Calvin
wire spacing for stretched wire ESL? Few Planars & Exotics 9 26th March 2009 12:37 AM
ESL Stator to Diaphrame Spacing bshaw147 Planars & Exotics 3 5th August 2008 07:29 AM
Wire Insulation for Wire stator Audio_idiot Planars & Exotics 6 25th May 2007 11:42 AM
stator spacing/voltage bias tade Planars & Exotics 2 28th June 2005 05:57 PM
Page generated in 0.05850 seconds (64.75% PHP - 35.25% MySQL) with 11 queries
