Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 17th March 2007, 06:52 AM   #1
Default SE Tube amps with electrostats?
I have recently heard that single ended tube amps don't work very good with esl's. Is this true?
Old 17th March 2007, 07:48 AM   #2
Calvin is offline Calvin  Germany
Calvin's Avatar
I don´t see any reason why this should be so!
They are terribly inefficient, so You´d be generating loads of heat and it´ll be not easy to find good tubes, but apart from that, there should be not much of a prob.
Had one running (it was even a SE Triode) with the incredible KR845 running on 2kV plate voltage and it drove up to 1nF load without probs.
jauu
Calvin
Old 17th March 2007, 07:58 AM   #3
Thats what i figured but i thought i had better make sure before i ordered any parts to start building a 304tl SE.
thanks
Old 17th March 2007, 08:52 AM   #4
Pano is offline Pano  United States
Pano's Avatar
I ran a pair of 811SET (IIRC) monoblocks on a set of double stacked Quad panels for awhile. About 20WPC. Plenty of power. But I don't think they liked the load much. Very bright and forward sounding. But waaaay better than the Quad 405 that was there before.
Ended up with 20WPC Class-A solid state.
All amps are different.
Take the Speaker Voltage Test!
Old 20th March 2007, 03:44 AM   #5
Default take a look at this page...
http://w3.mit.edu/cheever/www/6c33amp.htm
moray james
Old 21st March 2007, 09:54 AM   #6
willyCJ is offline willyCJ  United States
So are you planning on building an amp where you don't go to an 8 ohm apperant load between the amp and ESL? I'm starting to read on ESLs after making my first tube amp from scratch about a year ago. I want to run a low current, high voltage setup. Since tubes expect a roughly 5kOhm load, ESLs seem like a good match.
Old 21st March 2007, 03:46 PM   #7
I_Forgot's Avatar
The idea of using a SET amp to drive an ESL baffles me as much as the guys who want to break an ESL up into 3 or 4 separate drivers and make a crossover to drive them. Why would you want to drive a speaker as nearly perfect as an ESL with a high distortion amp? What's the point of using an ESL?
I_F
Old 21st March 2007, 06:59 PM   #8
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
I_F
Its because tube amplifiers produce light
Old 22nd March 2007, 06:47 AM   #9
Because he can?
Cheers
Audio_Idiot
For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! opc Swap Meet 23 2nd November 2009 06:04 PM
Are Carver TFM's good amps for driving Electrostats? CharlieM Solid State 1 20th February 2009 11:56 AM
Electrostats bbksv Planars & Exotics 10 8th February 2004 07:45 AM
Subwoofer for electrostats Adam Subwoofers 5 28th December 2001 08:56 PM
Page generated in 0.11268 seconds (82.31% PHP - 17.69% MySQL) with 10 queries
