Plasmatweeter - Page 25 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 25th February 2013, 03:53 AM   #241
Carlp is offline Carlp  United States
The museum was claiming more than a million volts capacity with their BIG van de graaff generator, though I don't know what they were using for the sound as it was smaller, nor what kind of power. I'm well beyond my knowledge about such things, but I'm certainly curious about the low end...
Old 25th February 2013, 11:19 PM   #242
asterkao's Avatar
Originally Posted by geraldfryjr View Post
No, I meant down to 300hz to 350hz and up to 20kHz of course.
The lowest frequency's are the hardest to produce as they require more displacement the lower you go.
To do this would require a lot of power!
I saw an example on 4hv.org that used a ceramic type transmitting tube.
From the video the flame was huge and was quite loud!
Very clean sounding when it wasn't clipping the audio.
I tried to search for it today but the site wouldn't let me sign in for some reason so it will take me some time to get that straightened out.
It was quite an impressive video.
jer
Hi Jer:
Thanks reply.
I think mid-range plasma of a narrow band operation will easy successful.
After testing ...... because ....
Pasma generate wavelength physic issue.
short wave length easy interrupted long wave length cause noise .
Aster
Old 25th February 2013, 11:21 PM   #243
asterkao's Avatar
a million volts
This make me panic.
Aster
Old 25th February 2013, 11:40 PM   #244
Yes, I often wondered if the flame got to a certain large size, that it might increase doppler distortions.
I also read the the noise issue diminishes as the flame frequency raises and is typically above 4.5Mhz is were it starts to be quiet.
FWIW
jer
Old 26th February 2013, 12:48 AM   #245
Originally Posted by asterkao View Post
a million volts
This make me panic.
Aster
Me too! Metal caging around the audience and lots of safety systems in place. I wouldn't have brought my wife and 2 kids into the room if not.
Carl
Old 17th March 2013, 09:01 PM   #246
A while back I had mentioned in another thread (that I can't seem to find now) of a 1kw plasma speaker that used a large transmitting tube (ceramic?) over at 4hv.org.
I just found it here,
Forums / High Voltage / Tl494 Big audio modulation Plasma Speaker / Tweeter 1kW - 4hv.org
Very impressive indeed!!!
Here is one more very cool setup,
http://www.youtube.com/watch?v=NeIAkKmUfn4
jer
Old 3rd September 2013, 02:24 AM   #247
asterkao's Avatar
Mid Plasma 555 and Plasma Tweeter working together
Old 3rd September 2013, 04:33 AM   #248
Very Cool !!!!
jer
Old 11th March 2015, 01:44 AM   #249
asterkao's Avatar
Plasma Mid and Plasma Tweeter working together
Plasmatweeter diy (germany?) hotlipswetpants Planars & Exotics 1 30th July 2004 04:18 PM
Copyright 1999-2017 diyAudio
