Plasmatweeter - Page 21 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 25th January 2011, 06:14 AM   #201
asterkao's Avatar
I still find the way to re-light itself.
Old 26th January 2011, 12:53 AM   #202
expert in tautology
bear's Avatar
Please find a way to place a grounded SHIELD on the unit!!
nice lookin though...
WAIT! A close look at the pix - YOU DO have a GROUNDED SHIELD! Good work!!
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 26th January 2011, 01:43 AM   #203
asterkao's Avatar
Hi Bear:
Yes,I shielding to Gnd already.
Separate to .... H-voltage power ,IF-modulation and RF-PA 3 parts.
If system don't shielding to gnd then L & R channel plasma tweeter will
interference ecah other cause system not work.
Old 27th January 2011, 02:49 AM   #204
okk is offline okk  China
okk's Avatar
Originally Posted by vogor View Post
In my ionofone operating anode voltage of 600V is included after the heating filament lamps, but the plasma still does not light itself, which generating the lamp you are using and what the voltage on the second grid, if you do not complicate the scheme to send vogor@yandex.ru
Hi, Vogor:
My circut is standard without any improvment. The tube is PL519, most famours one. Ug2 70 - 80V will be enogh, otherwise may be distroy the tube.
The feedback loop is impotent, need to adjust finely.
Good luky.
Okk
make it better.
Old 30th January 2011, 02:35 PM   #205
Default Hill Plasma
Originally Posted by abzug View Post
What does this have to do with anything?
You can contact me through forum PM.
I've been with contact with an owner and he said it does not hiss (though his is modified). But not to take his word, in the prototype I built, there is no hiss either--and I'm even using much higher power levels.
Corona discharges are noisy. Arcs are noisy. Glow discharges are not. Maybe the version you heard had a noisy regulator on the helium tank or whatever, but if the discharge is making noise, that means something's wrong with the supply and/or amplifier.
Did you read even one of my posts here? I've pointed out repeatedly that it is not necessary.
How you can confuse "electrodes" with "catalysts" is beyond me. And it's platinum-plated, not platinum.
The Hill Plasma does make a very low hissing sound but not objectionable.
Old 9th February 2011, 07:17 AM   #206
asterkao's Avatar
Plasma Tweeter
Finish picture
IF-Modulation block
A-B banchmark with Jensen RP-302
Mr211's Blog - Yahoo!?????
Old 10th February 2011, 06:48 PM   #207
Can someone explain to me in a laymans terms why most Plasma designs use a vacuum tube instead of solid state? Is it just easier to ramp up the voltage needed?
Old 12th February 2011, 12:34 AM   #208
asterkao's Avatar
Hi:
Could make feeling of sound different easy change by replace tube.
In Taiwan had an expert take 3 years to diy two type plasma tweeter (Semi-conductor by pwm & all Tube design ) to benchmark for sound feeling .
The result is design usage all tube solution got better performace.
Another reason the system need handle high voltage for Plasma radiation and The RF tube easy to handl this issue and no need tranformer to booster high voltage (transformer usually need specific design).
The circuit is simple and more easy DIY.
This is audio gear fans view point.
ASter
Old 12th February 2011, 03:32 AM   #209
jfitz57 is offline jfitz57  United States
One reason is it is DIY and you do not know if it will work until it works. You have time to see that a vacuum tube circuit is not working and turn it off. Got myself a box of NOS 29KQ6/PL521 tubes for $1 each and waiting for it to get warm enough to open the windows so I can start working on one.
Old 12th February 2011, 04:34 AM   #210
+3 F, -16 C now.
Plasmatweeter diy (germany?) hotlipswetpants Planars & Exotics 1 30th July 2004 04:18 PM
Copyright 1999-2017 diyAudio
