Full range planar speaker using neo magnets - Page 29 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 4th June 2013, 08:33 AM   #281
Originally Posted by WrineX View Post
might have a problem there in the resistance, headphones usually have higher resistance then speakers. so could be an impedance miss match.
The last pair I built were 6 ohms, and they still sound wonderful, as long as you don't turn them up too much depending on the type of music, if very bassy it cuts out the amp which switches off.But if you watch television they are O.K. I don't know if I can reduce the bass on the headphone setting yet, I hope I can, as the bass is really powerful.
HENRY
Old 4th June 2013, 08:43 AM   #282
My first pair were about 30 ohms, I haven't really tested the 2 side by side perhaps I should to see if there is much difference. I like them both anyway, best headphones I have ever heard.All 17 of my speakers in my living room sound great, all full range planars of my own designs, using neos and ferrites, normal and epsilon layouts, different sizes from A4 to 4' x 2'. Although the majority are 60 x 40 mm.
HENRY
Old 5th June 2013, 10:21 AM   #283
The 6 Ohm one is about 3 db louder than the 30 Ohm one. I have turned the bass down on my Amp by about 2 to 6 Ohms, trying to decide which one I prefer. It all depends on the music being played, and when you have all types of music all jumbled together you have to take pot luck with the bass. Some of the recordings are crap anyway with distortion and funny noises, which makes it very difficult to control the sound being heard. I have ordered 3 more cheap headphones, so I can dismantle them and build more full range planar headphones. I have also ordered a cheap headphone Amp, that can play 4 at the same time. This should make it easier to compare different designs neck to neck, and keep my brain occupied. Wish me luck!!
HENRY
Old 9th June 2013, 03:57 PM   #284
Have ordered 6 cheap headphones of different sizes and shapes, will be stripping them down and converting them to full range planars. To find out the best layout etc. Should keep me busy for a few weeks. Looking forward to the exercise. One of them is a wireless headphone, I hope there is enough room inside!? We will see how things pan out, wish me luck!!
HENRY
Old 30th July 2013, 10:00 PM   #285
Default RE-FRONTED MY 9-1 SYSTEM, SMALLER SIZE!
Showing my new layout, will be building more full range planars to use the larger size canvases which I replaced with the smaller ones, will decide what diaphragm layout I will use, should keep me busy for a little while yet! It was hard work hanging the new ones this weather!!
HENRY
Old 31st July 2013, 05:31 PM   #286
chinsettawong's Avatar
Very good idea!!! Nice!
Old 31st July 2013, 10:44 PM   #287
The big one on the front left uses plastic magnet tape 3 mm thick, and the smaller one on the left uses 3 mm thick neos. The neo one is 8 Db louder, but the 3 mm tape is a lot cheaper, sounds good.Had to replace the left rear surround speaker as it was making a funny noise. I hope it wasn't the amp, we shall see. If it is not the amp will be interesting to find out what was causing the noise. Couldn't see any thing wrong before. We shall see, hopefully.
HENRY
Old 8th August 2013, 03:42 PM   #288
I am in the process of doing some more re-builds, and finishing a pair of FRP using 3 mm thick plastic magnet tape, one uses the normal layout and the other an epsilon style layout , just to see which is best. Have also rebuilt a couple of my 60 x 40 mm FRP to improve the bass which can get a bit over powering at times.Still learning new things every day. Keeps me busy, will it never end!!!???
HENRY
Old 8th August 2013, 03:44 PM   #289
I'm glad to say it wasn't the amp, rebuilt the diaphragm using thicker mylar, it is OK now, made me realize I'm still learning. Big time.!!!
HENRY
Old 9th August 2013, 11:07 PM   #290
Default my latest design.
An epsilon variation tried for the first time, don't know how it will sound, we will have to wait and see, if no good will revert to normal layout.
HENRY
my 14 inch full range speaker! chinese Full Range 235 21st September 2010 01:30 PM
Where to find magnets???For Diy Planar floydturbo Planars & Exotics 8 27th July 2010 10:28 PM
16 Ohm Full-Range Speaker thelordash Chip Amps 13 23rd January 2009 05:13 PM
full range speaker for HT Jazzz Full Range 13 8th September 2006 08:27 PM
beginner full range speaker tacomaboy Full Range 5 12th January 2004 07:38 PM
Copyright 1999-2017 diyAudio
