Full range planar speaker using neo magnets - Page 12 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 11th September 2011, 04:23 AM   #111
tmblack is offline tmblack  United Kingdom
Henry
how far apart are the magnets, and how far is the plastic sheet from the magnets?
Old 11th September 2011, 10:21 AM   #112
The magnets are actually touching and the distance between the membrane and the magnets is 3 mm.
HENRY
Old 11th September 2011, 05:31 PM   #113
In the Apogee series the aluminum conductors run horizontally and there is a vertical gap about 1/4" between the rows of magnets.
Did Apogee use ceramic magnets or Neo?
All I need is a source of cheap magnets to try this!
Old 11th September 2011, 07:23 PM   #114
I don't think neos were available when the Apogees first came out! You can build a small 60 X 40 cm speaker using neos. This size is my latest design, as bigger ones were not really any louder than the small ones. A 4' x 2' was not really worth the extra magnets. I would recommend you use 50 x 6 x 3 mm magnets and use 3 mm wide aluminium foil. This would give you the highest sensitivity and would fit in with the size of the speaker.If you can't find any foil this size use scissors and cut it to this size, that is what I do. I must have cut about 450 meters up to now!!! I'm afraid magnets have increased considerably in price in the last few years.I got mine from China as this was the cheapest I could find, although the postage is quite high they still worked out cheaper in the long run. Although I don't know if this is still the case, as I have not bought any for quite a while!
HENRY
Old 11th September 2011, 08:59 PM   #115
My Apogee Duette's have ceramic magnets.
Jer
Old 12th September 2011, 07:43 AM   #116
Jer
Mine too.
Old 12th September 2011, 10:07 AM   #117
Default What about building something this size..
Anybody has tried this size?
I spent more time at the computer than at the "listening room", as many of you are..
Magnepan Mini Maggie Desktop Speaker System (Playback 48) | AVguide
A cold amp is a sad amp... I like them warm at least
Old 12th September 2011, 10:10 AM   #118
Default another picture
seems "easy" to clone, and uses few magnets
it reminds me the moonsons
File Type: jpg Mini_Maggie_Desktop-Panel--interior-view.jpg (62.9 KB, 474 views)
Old 12th September 2011, 07:49 PM   #119
The smallest FRP that I have built up to now is 14.5 x 20 inches, using 116 50 x 12.7 x 3 mm neo magnets in each one. I built these to fit a underfloor loaded speaker which used 1 18" cone and 2 piezo speakers.I built the planar to try out the small size,in comparison to my 60 x 40 mm size of which I have 11 hanging up in my living room with my new 9.1 amp. I'm glad they didn't cost me 1500 a pair or a trio.
HENRY
Old 12th September 2011, 09:09 PM   #120
Magnepan must be using ceramic magnets, the MMG-W is very cheap and similar in size.
Anyone heard that one?
my 14 inch full range speaker! chinese Full Range 235 21st September 2010 02:30 PM
Where to find magnets???For Diy Planar floydturbo Planars & Exotics 8 27th July 2010 11:28 PM
16 Ohm Full-Range Speaker thelordash Chip Amps 13 23rd January 2009 06:13 PM
full range speaker for HT Jazzz Full Range 13 8th September 2006 09:27 PM
beginner full range speaker tacomaboy Full Range 5 12th January 2004 08:38 PM
Copyright 1999-2017 diyAudio
