Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 17th January 2007, 10:31 PM   #1
Ang is offline Ang  United States
Default binding posts directly on neo8
Since I'm experimenting with some neo8's in different configurations I was wondering if I there was a binding post I could attach directly to the planars. (seems better than soldering to a wire to a banana) I've seen some subs with the feature, just don't know if PE sells something that would work.
Old 18th January 2007, 01:33 PM   #2
badman is offline badman  United States
Custom Title
badman's Avatar
It's going to be hard to make a good mechanical fastening to hold a binding post there, that won't stress fracture the terminal. And you can't simply mount it into most solid adhesives, because while outgassing the solvents could damage the adhesives in the planar.
Easy-on terminals are the order of the day, crimpable, cheap. Bring the planar to radioshack and get the right ones from the connector bin, for temporary use, you can crimp them with linesman's or other heavy duty pliers (or preferably, a crimping tool proper)
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
binding posts h_a Parts 21 13th January 2009 12:10 AM
kef 107 binding posts dayking79 Multi-Way 1 1st September 2008 12:47 PM
Binding posts cp642 Parts 6 16th November 2001 03:10 PM
Page generated in 0.06885 seconds (63.02% PHP - 36.98% MySQL) with 11 queries
