DIY Planar magnetic Hybride - Page 8 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 9th August 2012, 02:26 PM   #71
Default SOME MORE REBUILDS.
46 rows on this re-design, using the 3mm tape. Easier to use than 4.5mm tape used previously. Prefer the horizontal design seems to give better bass than the vertical layout. Although you get more turns using horizontal than vertical position on diaphragm, which is harder to place on diaphragm, more fiddling. Resistance 6.7 ohms give or take a couple of tenths.
HENRY
Old 9th August 2012, 02:48 PM   #72
Default Would appreciate a little more help
The magnets are attached (glued, magnetically attached, other?) to a steel mesh grill - yes/no? - or makes no difference as to "grill material"?
Magnets are arranged in alternating polarity by rows ? (ie one end is "North" and adjacent is "South") - yes/no?
Could you give link to magnets - exactly - ie where to purchase or what to look for? Possibly in US if you are familiar. If not then in UK as I have relatives.
Same for tape - link, thickness, material, etc.
I have Mylar so will use this as membrane
INITIAL Current flow in tape makes no difference as it alternates also row by row? - or is there an initial orientation with respect to magnet polarity that needs to be considered?
Tape is just hooked to amplifier outputs - no other circuitry required?
Response to 20Hz is measured or estimated?
SPL's that can be obtained - your estimate
Other "gotchas" to be aware of.
Thanks for help.
I fixed buzz in Sonigistix Monsoon planar magnetic drivers Andersonix Planars & Exotics 35 12th August 2013 07:27 PM
WTB: Raidho FTT75 planar magnetic tweeter luvdunhill Swap Meet 9 7th December 2008 04:51 PM
mugen hybride jopie Tubes / Valves 2 2nd April 2008 05:09 PM
FS: 1 Pair of Bohlender A1 Planar Magnetic Loudspeakers dvdvideo Swap Meet 0 11th May 2005 06:11 AM
DIY Hybride amplifiers Gydotron Tubes / Valves 21 22nd February 2005 04:37 PM
Copyright 1999-2017 diyAudio
