| Planars & Exotics ESL's, planars, and alternative technologies |
#11 | |
#12 | |
If you had a low pressure low volume air source pushing from behind, you could flex the bubble as much, or as little as you want. I think I'm gonna love this thread -Casey
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again. |
#13 | |
There is one more problem. Water is very good breeding ground for microbes. First you must make the liquid denatured, maybe use even a UV-lamp. And somehow be able to wash stators time to time inside if bubbles pops and wet them. Still... Liquid speaker would be great! |
#14 |
OK, this "whacky" idea has really got me thinkin'
Wouldn't it be possible to replace the crosslinks in the bubble "chain" with serations (spl?) on the upright(s)? The irregular surface should grab the solution, and pull it up. A soap bubble Jacobs Ladder if you will. If this worked, it would simplify the mechanics significantly. Basically two serated wires slowly spinning in a continual loop. -Casey Edit:Spelling
#15 |
The ideal speaker for Lawrence Welk or Don Ho music!
(if you get it, you remember the 60's) |
#16 |
Discussed with ESL gurus and this idea wonīt propably work
![]() Stators attract a bubble because they have different potential. If the bubble is not exactly in the middle the closer stator suck it immediately. Thatīs because the bubble doesnīt have enough tensile strength. So what to do? Design a system that only push a bubble from each side? Er... |
#17 |
How about a "Heil Air Motion Bubble"
Have the stators push from the sides, squeezing it.
#18 | |
#19 |
hmmnn... there is an electrical contribution to surface tension.. i.e., if you inject electrons into a liquid, the surface tension changes...
maybe a suitable setup to modulate the surface tension of a liquid surface via polarizing opposing stators... hmmnn.. have to give this some more thought... http://en.wikipedia.org/wiki/Electrowetting http://www.ececs.uc.edu/devices/NDL_Research.html one can envision a "dancing droplets" speaker.. or some such John L.
"...His brain is squirming like a toad..." Jim Morrison |
| Onix & soap needs a re-cap | fatmarley | Parts | 27 | 11th February 2011 01:36 PM |
| SOAP preamp PCB,s | zei | Group Buys | 19 | 11th May 2009 09:26 AM |
| Horn mouth bubble size | MaVo | Subwoofers | 1 | 25th February 2009 11:59 AM |
| Output of Onix Soap PS | kptseng | Solid State | 2 | 16th December 2005 12:12 AM |
| The Bubble for BG Ribbon Tweeters | TheoM | Multi-Way | 0 | 9th February 2004 04:20 AM |
| Page generated in 0.09500 seconds (80.71% PHP - 19.29% MySQL) with 10 queries |
