| Planars & Exotics ESL's, planars, and alternative technologies |
I found these while looking for cheap SMPS power supplies for a class-D project.
Cheap power supply link The output is 2KV AC at 10ma; this should give roughly 2.8Kv DC if put through a bridge rectifier. A voltage doubler would let this work very nicely for a small, cheap electrostatic solution. Would these work? |
#2 |
Yes, it would work but that kind of current can do some real damage if you touch the wrong place. I don't recommend it.
Keep looking... I_F |
#3 | |
What if I were to add a small isolation transformer or fuse? I'd like to try electrostatic speakers, and I'm poor. |
#4 |
You can use this device, BUT.
You will need a large series resistor to reduce the available current. Secondly, you will need good filtering at the output, since it runs at ~30kHz. You do not want 30kHz modulation on the diaphragm. NOTE: THE CURRENT (@ 3kV) AVAILABLE IS DANGEROUS/DEADLY That means extra parts. The input is 12vdc @ 1 amp. A fair amount of power - so you need a fairly large "wall wart" to run it, or else you have to build yourself a power supply - more parts. The open circuit is 3kv - you'll get 3kv, it's being run open circuit for all intents and purposes here. It's probably equal or less in cost to take a typical small transformer with a secondary from 120vac or higher and build a diode/capacitive multiplier circuit to get the requisite HV that you need. This is the traditional and typical time proven method. One company takes a 120vac ---> 12vac transformer and then connects a second identical transformer backwards - it gets you back to 120vac, but ur isolated from the line AND you didn't have to buy an "expensive" transformer, just two cheapo transformers! Then they use a diode/cap multiplier circuit from there... Given the low current being drawn you can likely get away with using something like a 120-->12 into a 6--->120 and get 240vac out to go to the multiplier and save a few sections of multiplier... _-_-bear
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#5 | |
I also agree that this module is way to powerful for this purpose. The additional cost for the heavy 12V supply and safety resistors/filtering will cancel out any benefits over the 'classic' approach.
If you can find transformers with 2 seperate 120V primaries you can wire one for 120/6 and the second for 6/240. Just don't feed more volts into a winding than it was rated for, to avoid core saturation. |
#6 |
and the output is AC, but you need DC. Additional high voltage parts are required, which easily tripple the costs at the end. Capaciti |
#7 | |
Check the on-line surplus dealers for HV power supplies. In the past I have found 5 kV at 1 mA adjustable supplies pulled from copy machines for $7. They are cheap because people figure they are useless with such low output current which is exactly what the ESL builder wants. I just found this in the first place I looked in about 30 seconds: http://www.herbach.com/Merchant2/mer...egory_Code=PWS 2000 VDC, 5500 VDC both well under 1 mA, $7.95. Brand new, available in large quantities in case you decide to go into production. What more could you want? here's an adjustable one for a few dollars more, and it has a 24V output, too: http://www.herbach.com/Merchant2/mer...egory_Code=PWS The output current is a little high, and you'll need to put a load resistor on this one, but it is adjustable over the range of 3kV-7kV, right about where you want to be able to adjust it. I_F |
#8 | |
Awesome! Now, to find some perforated metal. |
| Solid state power suppy for CAT SL-1 | pwan | Tubes / Valves | 0 | 7th January 2008 02:57 PM |
| Any good place to buy cheap Solid State Disk Drives? | multiplexor | Parts | 22 | 30th September 2002 03:20 AM |
| The Solid State Wiki - Your solid state reference guide | Jason | Solid State | 0 | 25th June 2002 05:26 PM |
| Page generated in 0.10760 seconds (79.63% PHP - 20.37% MySQL) with 10 queries |
