..didn't know how they sound till i made me one.. - Page 14 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 18th November 2006, 10:48 PM   #131
stokessd's Avatar
The seas woofers are amazing down low. They have an insane breakup mode that is like 20 dB high, but that's up in the midrange. Those drivers are great if you notch the living crap out of the breakup region. Because I'm actively crossing over the woofers so far away from that region, I didn't bother doing anything with it. Not turning on the panel amps and listening, there isn't anything beyond bass coming out of my woofer boxes. Thump thump thump.
The quads are an interesting design, quite unique from anything else out there. Really outstanding bit of engineering when you consider the limited materials they had to work with back then. The treble panels will arc at about 3KV give or take (the quads don't have the tightest manufacturing tolerances out there). The treble panels have the conductive portions painted inside the stators, and the bass panels have the conductive regions painted on the outside of the stators. The entire membrane is covered in a conductive coating which in many cases has disappeared over the decades (again, they didn't have the materials and coating methods we have now)
The attachment points are metal tabs riveted to the plastic and the conductive paint covers the rivet. When soldering to those tabs, be very quick.
You may want to try an experiment where you put cardboard baffles on the sides of the treble panel to imitate the width of the speaker, you'll find that the panels will play a whole lot lower and you won't have a hole in your midrange.
Sheldon
Old 18th November 2006, 11:10 PM   #132
v-bro is offline v-bro  Netherlands
v-bro's Avatar
Allright, so what are the crossover frequencies, does anyone know?
And I did experiment with baffles, indeed the were extended in the lower range a bit. I didn't mind at the time, but I want to make some kind of baffle and protective grill for them after refurbishment...
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 20th November 2006, 05:13 PM   #133
tmyr is offline tmyr  Greece
.. aaa a baffle is a very interesting accesory and it does lots of work preventing compressed air from the forward movement of the membrane go around the frame and hit membrane at the back helping forward movement some more . simple words aerodynamicaly speaking but this is the case as i persive it.
using it helps extend bass region (less dipole canselation) and reduce membrane movement thus more spl in general _if u have the additional amp power that is..
such a baffle should be heavy as it is hit from both sides with opposite air presure and is prone to vibrate.
my experiment showed the bennefits of a baffle and the weeknesses of a light carton constraction.
the whole idea is not that beautifull . maybe thats why people dont use it much . but is very effective..
can make your esl sound bigger depenting on the size of that baffle ..
stokessd .. yes i use a "DALE ROX-2 40MŮ GK" cyan in color big (for hv) resistor .. another nice find at work.
Old 20th November 2006, 06:48 PM   #134
405man is offline 405man  Scotland
Has anyone tried curved baffles like the mouth of a large horn
Stuart
Old 22nd November 2006, 04:49 PM   #135
I_Forgot's Avatar
Baffles extend the frequency response downward but they don't provide any higher SPL. That's why most people go with larger speakers instead of small ones with baffles. If you've accepted the idea of putting a 3' wide speaker in the room, why not make it 3' of active speaker instead of 1' of speaker and 2' of baffle? Guess which will play louder...
I_F
Old 23rd November 2006, 12:55 PM   #136
yes indeed this is absolutly true ..
i was refering to a given speaker wich could improove its performance with this accesoir - not design and constract a baffled one . if baffle reduces membraine movement (x-nominal) then you could drive it with some more watts to make panel play louder .
Old 26th November 2006, 02:51 PM   #137
stokessd's Avatar
Sorry, I wasn't clear. I was suggesting the baffles for the guy who is using the quad tweeter by itself. As it stands in his picture, the panel is 6 inches wide and is rolling off quite high.
Sheldon
Old 26th November 2006, 10:01 PM   #138
v-bro's Avatar
Yup, me... I will try Sheldon, thanx. But where would it aproximately roll
off? A field-soundengineer from work measured the freq spectrum of the whole system (with woofer) in my very room and it didn't look bad...He used some very small professional field-spectrum analizer...aprox. 1 meter distance, several angles...
I don't like the idea of baffles, would small baffles pointing to the rear (from the sides). do the job? (like a U-shaped baffle...) Littlebit of (thin, breathable) foam glued behing it (between the edges of the baffle)?
Thanks....
BILL and TILL elnino86 Parts 0 14th December 2008 08:21 PM
Am I the only person that DIDN'T like their B20's ?!? Nihilist Full Range 41 4th July 2008 03:38 PM
Attention Raffi and Till (Roemhild) ConExp Full Range 52 23rd October 2006 10:59 AM
Less than 38.000 posts till the 1 mill Bakmeel The Lounge 1 6th July 2006 09:48 PM
home made surround sound Hitman Digital Source 7 22nd December 2002 07:15 AM
Copyright ©1999-2017 diyAudio
