| Planars & Exotics ESL's, planars, and alternative technologies |
#61 |
hey don't go crazy with your plasma dude!
i got a plasma cutter also!! ![]() Plasma is more of an eccentric technology! it is not an "easy" source of sound wich seems to require knowledge time and consumables thylantyr: I get your point, and you are right. BUT There has beel already plenty of posts about this subject, so i was trying to get more into data and objective kinda thread..wich makes for a change don't you think ? i love wine, and i don't choose it by it's chemical constitution BUT i'd however would be interested to know it precisly just for the kowledge and pleasure |
#62 |
@Nixie comparing a tiny flame against a huge diaphragm. Congratulations for this apple-peas thing At least can You build excellent, marketable and safe systems with this principle and You don´t need complex electronics. And best of all it has proven its qualities in several thousands of applications whereas the plasma is still kind of freaky with laboratory status. Something that imho prevents this system from becoming the best (at least with the momentary state of art). jauu Calvin btw. an Hello and a signature makes a post a bit friendlier |
#63 |
Searching for the best speaker is like searching for the best woman; ....... ....... good luck!.................
drs M.J. Dijkstra |
#64 | ||||||||
Banned
The fact is, the comparison is valid by virtue of the two drivers serving the exact same purpose. Quote:
#65 |
Hey Nixie
could you please post some links to your threads and information about ur device. I always thought that Plasma/ionic tweeters required some gazeous matter ( helium ? ) to be feed non stop so i am interested for more intormation And you are also 100% right to be claiming your solution as the only valid point is making sound and if it does then we can compare the quality of the output ... |
#66 |
Quote: "as the only valid point is making sound
and if it does then we can compare the quality of the output" there are more things to consider when choosing a loudspeaker driver/s than this. You need to be concerned with what it is you need/want the driver/s to do and you also need to consider the enviornment in which you intend to have the driver/s do that job. Dispersion caracteristics are of major concern. Driver directivity is a very important consideration and will often determine what driver/s you can use or need to use to achieve your intended goal. Playback level and your design specific distortion level will also impact your choice of driver/s. Perfect for your living room and perfect for small hall are two different things. If all you really want to listen to is small acoustic recordings then you might find "perfect" in a small size quality fullrange driver. But if you want to play electronic music or full scale symphony you will find that your "perfect" choice will look a little bit different. It's a big fish kettle! Regards Moray James.
moray james |
#67 | ||||
Banned
#68 |
oh well then, You´re so damn right. So excuse me for a while, I´ve to listen to my Best System :-) jauu Calvin |
#69 |
Banned
Hehe I am...
I'd write a longer reply, but my thumb had an unfortunate meeting with the milling machine's bit so my typing is going to be too slow for a couple of days...good thing they didn't use stitches and only surgical glue >.< |
| Amps for the rest of us? | dzzmiller | Full Range | 44 | 6th April 2009 04:18 PM |
| can trafo laminations rest on chassis? | CarlyBoy | Tubes / Valves | 8 | 27th December 2008 12:07 AM |
| for sale: the rest of my stuff. | vincentrubble | Swap Meet | 10 | 15th February 2008 04:45 PM |
| May he rest in peace! | Audiofanatic | Everything Else | 3 | 5th July 2003 10:55 PM |
| Goeie dag, G'day, and Hi to the rest. | JDeV | Introductions | 16 | 8th November 2002 12:33 PM |
| Page generated in 0.12230 seconds (84.01% PHP - 15.99% MySQL) with 11 queries |
