| Planars & Exotics ESL's, planars, and alternative technologies |
#11 |
I think even looking at it from a measurements only point you'll still find they all have strengths and weaknesses with no clear winner.
Not to mention the huge variations in radiation patterns from ESL to ribbon to cones/domes. |
#12 |
then what do we have to compare?
Is there any way to compare drivers at all ? It doesn't look like, if i listen to what you are all sayin .. So we are reproducing a source, with a certain fidelity, but we can't measure that, and we can't compare much because it is all sooooo different .. Even though a FWD 4 banger car is quite different than a RWD V8 rod, you can still compare them on acceleration or handling ... |
#13 |
A bit of an issue is that a loudspeaker doesn't really HAVE a frequency response -- it has zillions of them!
A car's acceleration can be measured so you can get a meaningful number. An amplifier has one input and one output between which response can be measured absolutely. But a loudspeaker has an infinite number of outputs, all depending where in space you measure from (variations in left, right, up, down, and how far away). There is no single "output port". So, suppose you decide to measure from some fixed distance (say 1 meter) in some fixed direction (say "on-axis"), then can you decide whether a speaker is better in terms of frequency response? Maybe, but only for that listening position... and only for listeners in an anechoic chamber! Because, like it or not, the speaker radiates in all directions, and with different responses in each direction, and that radiation bounces around the room and will come back to the listener, and that reflected sound will most definitely have a huge effect on the sound. So the speaker's actually-used response will also differ depending on what room it is in, and where it is in that room, and where the listener is seated. A "perfect speaker" would have to somehow remove the reflections that the room adds. Add into the mix distortion (which varies with both frequency and with drive level, and sometimes with how long the driver has been playing and how loudly), efficiency, load impedance presented to the amplifier, and max SPL capability. What do you want to proclaim the "most important" characteristic? That would probably depend on what is most critical to your ears and to the rest of your setup. Measurements can tell you a lot, but you'll probably still have to listen to a speaker to make the final call on it. |
#14 | |
do auditions with human ears, a new concept for many .. lol Take the easy path, you will be happier. One loudspeaker design doesn't solve all the needs, you have to design a loudspeaker optimized to meet specific goals. Define your goals and then make a list of driver candidates and do auditions. Pick the lesser of the evils, there is no perfect driver or loudspeaker. |
#15 |
That about sums things up just buy the one that you like the best. Funny that's how we buy everything else and the only time that it dosen't work is when we don't trust out own judgment. Regards Moray James.
moray james |
#16 |
GRRRRRRRRRRRR guy c'mon ...
u inderstand and acknkoledge everything you are saying .... this is how it works NORMALLY that said, I DONT WANNA PLAN MY MOVE ON THIS i just wanna LEARN a bit more .. I WANT FACTS!!!! BRING ON THE GRAPHS!!! stop going back to the " buy what u like " that's not the point of my thread ... i want to learn the different properties of each technology ... |
#17 |
The RAAL ribbon website technology section describes EQUAFIELD as a breakthrough in homogenous magnetic field across the gap. Is this just hype-speak, or some good engineering improvements on the tradition pole piece design? Any ideas on how to model EQUAFIELD?
"EQUAFIELD® technology: The magnetic field in RAAL ribbons is homogenous. Regarding the width of the gap, it is designed to have the same strength at the ribbon edges, as well as at the ribbon middle portion. It reduces the stress at the ribbon foil dramatically. The distortion, too. To get the precisely shaped field, through the gap width and depth, we’ve extensively used the FEM and BEM magnetic circuits analysis software. In order to obtain such a field in real magnetic circuit, very strong NdFeB magnets have been precisely machined, prior to magnetisation, in very special shape. Making the magnetic field homogenous, sacrifices the strength of it, but efficiency should easily be changed for low stress and low linear and nonlinear distortion." |
#18 |
#19 |
1977 patent on forming magnet poles for a more homogenous ribbon magnetic field. Is this was RAAL means by EQUAFIELD?
#20 |
All drivers are flawed, but in different ways. You ask for data, but there are so many ways of measuring that you can only take that as a guide, unless you did the comparative tests yourself in strictly controlled conditions and then know enough to interpret the data in a meaningful way.
With the current state of the art, using any technology, there will never be a ultimate "best driver", but half the fun in this hobby is trying to find the best for you.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
| Amps for the rest of us? | dzzmiller | Full Range | 44 | 6th April 2009 04:18 PM |
| can trafo laminations rest on chassis? | CarlyBoy | Tubes / Valves | 8 | 27th December 2008 12:07 AM |
| for sale: the rest of my stuff. | vincentrubble | Swap Meet | 10 | 15th February 2008 04:45 PM |
| May he rest in peace! | Audiofanatic | Everything Else | 3 | 5th July 2003 10:55 PM |
| Goeie dag, G'day, and Hi to the rest. | JDeV | Introductions | 16 | 8th November 2002 12:33 PM |
