Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 3rd June 2006, 05:05 AM   #1
Send a message via AIM to Spasticteapot
Default Motor-based planar speakers-can it be done?
I've been looking through speakers, and it appears that some rather decent speakers (which more-or-less fit the definition of "planars") use a combination of a standard electromagnetic motor and another non-electrically active material to actually make the sound. Examples include the Soundpads and "Personal Planars".
Soundpads:
http://www.thinkgeek.com/electronics/audio/6bd8/
Odd wire-magnet-and-diaphragm design I don't quite understand:
My DIY planar speaker!
"Personal Planars"
http://www.decware.com/panels.htm
I personally like the idea of using a standard electromagnet assembly to drive a flat panel; that way, one can use a standard amplifier without transformers or high voltage, while keeping a large degree of the excellent sound associated with planars.
Also, I was thinking about using a method of driving these speakers used in "featherweight" R/C airplanes: Rotational actuators.
You can see one here:
http://www.ekmpowershop2.com/ekmps/s...T&productid=77
By placing a magnet in the center of a coil, you can make it spin in alternating directions by putting A/C current through the coil. Once the vibrations are produced, you then just apply 'em to the speaker membrane. However, due to inertia, I doubt these would work well at high frequencies.
Alternately, one could put a coil on the membrane and have it around a centrally placed magnet, somewhat like conventional speakers.
Finally, one could also try a piston-style design, with a small magnet with a coil on each side, running push-pull. You then thread a pushrod out to the membrane; using a high-strength magnet, you'd likely get decent efficiency, too.
So, any tips for doing this?
Or am I out of my gourd?
Old 3rd June 2006, 06:00 AM   #2
dshortt9's Avatar
It must be something in the Bratwurst.
Old 3rd June 2006, 06:12 AM   #3
dshortt9's Avatar
Seriously:
http://www.magnepan.com/maggie_tech.php
Old 4th June 2006, 01:00 AM   #4
thadman is offline thadman  United States
by using a voicecoil you raise the moving mass of the driver greatly, which defeats the main purpose of the planar/ribbon design (excellent transient response).
Old 4th June 2006, 01:30 AM   #5
theAnonymous1's Avatar
I have no personal experience with much of what you posted other than the "soundpads", and I don't recommend them for anything other than pure novelty.
"Distributed Mode Loudspeaker" is the technical term for them, developed by a company called NXT. Its takes a lot of research, development, and access to the right materials to even come close to making a "DML" worthy of listening to. Even "DML" products made by big companies fall extremely short of anything close to HiFi.
I have spent many hours and quite a few dollars messing with this technology, and I don't consider any of it well spent.
Old 4th June 2006, 03:37 PM   #6
el`Ol is offline el`Ol  Germany
Maybe you don`t know these:
http://www.sibatech.co.jp/FAL/FAL%20index.htm
Old 4th June 2006, 04:38 PM   #7
I guess you've got a point.
One idea (shown in the second link) is to put an extrelely long, thin coil of ordinary copper magnet wire along the length of a mylar ribbon. Although not as thin or as light as a real ribbon driver, you would'nt need transformers to drive it, and it could be made relatively cheaply if a source for neodiyum magnets could be found. Efficiency likely would'nt be too bad, either.
EDIT:
Now with picture! Can you tell I made it in MS-paint?
Old 5th June 2006, 08:37 PM   #8
Search for neodymium at Ebay yields 632 hits.
Old 6th June 2006, 10:22 PM   #9
Ron E is offline Ron E  United States
Ron E's Avatar
Museatex did the voice coil on planar diaphragm thing many years ago.
I know they cost a lot for what they were and they never went over well. Supposedly they sounded good when dialed in, but I don't believe what I don't hear. 90%+ of high end audio is just a con game.
Manger is essentially what you describe, but with damping elements and variable stiffness. I haven't seen a DIY Manger, why not try your own?
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 6th June 2006, 11:06 PM   #10
Hmm...interesting.
I was wondering about the viability of speakers using a standard coil mounted in the center of a taut-streched piece of plastic. (This would be a lot like an electrostatic speaker.) Using a magnet on each side of the coil, you could drive it in both directions equally. As an added bonus, the field remains somewhat linear througout; as the coil moves farther from one, it moves closer to the other.
Also, could someone explain how the "personal planars" speakers work? I can't figure it out.
I wish I was'nt going on a !#$!$!@#$ vacation in three days.
Rega Planar 3 Motor(original model) height adjustment? GCD750 Analogue Source 40 26th November 2008 01:46 PM
WTB: Rega Planar 3 motor upgrade zacster Swap Meet 0 1st November 2007 01:14 AM
Links To Making Planar Speakers idaho Planars & Exotics 5 16th June 2007 12:02 PM
Page generated in 0.12351 seconds (82.65% PHP - 17.35% MySQL) with 11 queries
