Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 8th May 2006, 10:52 PM   #1
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
Default Mixed feedback
Recently i found the following article for improving output tranformer's performance.Maybe it would be useful for ESLs , especially lower quality trannies ?
http://www.lundahl.se/pdfs/papers/feedbck.pdf
Lukas.
Old 9th May 2006, 11:58 AM   #2
Looks like a negative resistance to me.
It might not be suitable for driving capacitive loads like esl's.
Old 13th May 2006, 06:20 AM   #3
orjan is offline orjan  Sweden
The negativ fedback is only set to be enough to nearly cancel the serial resistans in the primary.
Old 13th May 2006, 08:28 AM   #4
maudio is offline maudio  Netherlands
Yes, and the winding resistance of the primaire is the least of your worries when designing an ESL-transformer
What makes a good esl transformer so difficult to design is the combination of required output voltage (together with the v/turn ratio determining # of sec turns) and the large frequency range: the low frequency limit requires a large # of prim turns but the high limit requires low internal capacitances and low leak, what in turn requires as little turns as possible. In other words, the problems are at the secundairy side.
I am currently trying to design an amplifier/transformer combination that includes the transformer in the feedback loop. But it proves very difficult to obtain enough bandwidth
Old 13th May 2006, 11:55 PM   #5
jcx is offline jcx  United States
the point is that you're missing is that cancelling the pri resistive current causes a very large reduction in low frequency distortion
http://www.analog.com/library/analog..._handbook.html
chapter 6 ~ 6.70+
the question is could you usefully rely on this to extend esl transformer usable bandwidth lower limit
Old 14th May 2006, 08:19 AM   #6
Interesting paper, thanks for the link!
I believe this method could to some extend be useful to lower low frequency distortion by the transfo, if it could be made to work properly in capacitive loads. But than again, I don't believe low frequency distortion is something to worry about. Transformer distortion will be overshadowed by other esl-related problems anyway (resonance, non-uniform membrame motion etc) in the low freq range.
But to answer your question, it will not extend the low frequency limit. The lower bandwidth limit of a practical ESL transformer is not set by distortion problems but by core saturation limits that impose a hard limit on the voltage the transfo can handle at a certain frequency, derating linear with frequency. In addition primairy inductance sets another limit (Zprim must not drop below what the amp can drive @ 20 hz). Whatever comes first sets the limit.
Old 16th May 2006, 06:34 PM   #7
Well, the primary inductance is only a small signal aproximation. At large signals, close to core saturation, the value decreases.
And, yes, it works. I used it with line level transformers. It extends the usfull, as in some set distorsion value , low frequncy limit.
With transformers you could do as in quad 63s, use 2 for each esl. Then you can have half the voltage ratio.
Old 16th May 2006, 08:37 PM   #8
That's a good way of doing things but the price you pay is lower primaire inductance as both primaire coils are in parallel and they don't share the same magnetic circuit.
Even better solution is therefore to place the two coil-former from those two tranformers on one core, which can be done by using two coil-formers on a double C-core. To my knowledge this is the best way to make an ESL-transformer.
At least I hope so, I am trying it right now
Old 17th May 2006, 07:39 AM   #9
Yes, yes, yes -
and we are all waiting for you, to have grate success -
and tell us all about...
Frank
Mixed signals??? genmin Car Audio 4 12th February 2009 06:58 PM
mixed bias TUBESMAN Tubes / Valves 2 15th January 2009 01:19 AM
Puzzle of 6 mixed up Aleph 2 pyro2006 Pass Labs 8 29th March 2007 09:06 PM
Page generated in 0.09642 seconds (77.41% PHP - 22.59% MySQL) with 10 queries
