Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 5th May 2006, 06:53 PM   #11
The Peasant's Avatar
You can change the input cap and the roll-off cap, then you'd get some sort of 12dB/oct (2nd order) filter effect.
Sure, but then as Sreten points out, I would have to adjust the REL crossover level to compensate for the reduced subwoofer bass output. However, this is probably the best idea that I have seen so far.
If you have not replaced the electrolytic caps inside the interface box with film caps, do so.
Yes, ages ago!
Alternately you could put some nice film caps between the amp and the speaker.
This seems to be quite impractical to me, as many microfarads are required to pass even the midrange at this impedance, never mind the upper bass.
Also, there are two versions of the interface box - one has the "HF" xfmr coming in lower than the other by an octave or so...
Is this determined by the switch from 250uF to 50uF for the electrolytic capacitor for the high frequency transformer, or the upgrade to the medallion transformer itself?
I have tried increasing the resistor value in series with the low freq. transformer to 3 ohms, this did not reduce the lower bass much at all. When I get some time I will try the different transformer primary taps to see if that works better on the lower bass.
Thank you to everyone for all the suggestions!
Take care,
Doug
The Electronic Peasant
www.electronicpeasant.com
Old 5th May 2006, 07:01 PM   #12
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
Send a message via Skype™ to Bazukaz
"Don't fix what isn't broken"
ESLs can reproduce really clean and undistorted bass.
Should't you just roll of subwoofer earlier ?
That's my suggestion.
Old 6th May 2006, 12:00 AM   #13
expert in tautology
bear's Avatar
Oh, the sub runs off the speaker lines??
Too bad. You could open it up and make it line level?
The resistor in series reduces the highs, or so I am led to believe...
The main change in the HF sections freq roll in is/was the caps.
_-_-bear
_-_-bear
http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
Where to crossover, don't want audible bass mikee55 Subwoofers 15 6th October 2008 06:06 PM
Mid-bass dipole arrays for Acoustat ESL's JmanGTA Subwoofers 1 24th September 2008 04:02 PM
need Acoustat bass transformer... moray james Planars & Exotics 2 15th February 2007 07:22 PM
series crossover with 2.5 way bass madinoz Multi-Way 18 8th June 2004 12:55 AM
Copyright ©1999-2013 diyAudio
