Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 25th March 2006, 07:12 AM   #1
Send a message via Yahoo to taichiguy
Default Inverted ESL
I'm intrigued by the "inverted" esl's from FinalSound which, unlike typical esl's, applies the bias charge to the stators and feeds the audio signal to the diaphram. Their website says there is a sealed conductor inside the diaphram (as opposed to a surface coating?)--- so now I'm wondering; how did they do that?
Would the diaphram need to be less resistive in this case, since it takes the audio signal rather than a steady bias charge?
The design's impedence is said to be at least 3 ohms across the entire frequency spectrum (more amp friendly) and is implied to be inherently safer.
I hope that someone here more knowledgeable than myself (that would be most of you) will check this out (link below) and share your thoughts on it.
http://finalsound.com/
taichiguy
(charlie)
Old 25th March 2006, 11:30 AM   #2
SY's Avatar
The clue is their stated thickness for the diaphragm- 12u, about double the usual 6u thickness. It would appear that this is formed from laminating two films together, conductive side in. I haven't searched for their patent app yet, but I'll wager that this is the "secret."
What the actual advantage of this is, as opposed to the claims of the blitheringly stupid ad copy, is quite unclear other than, "it's different."
I would love to see the withering paragraph in Augsperger's JAES patent column. And to meet the marketing guy who came up with the rather ominous "Final Solution" slogan.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 25th March 2006, 01:31 PM   #3
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
I am not a big expert , but i didn't like their advertisements.Stating that ESL directivity is an advantage ... More than strange.
Also , i don't understand how they overcome charge migration by this technology ...
Old 25th March 2006, 01:56 PM   #4
SY's Avatar
OK, I've found their US application and it's not as off-putting as the ad copy. But I'm scratching my head to try to see what's really new.
Old 26th March 2006, 07:11 AM   #5
Calvin is offline Calvin  Germany
Calvin's Avatar
Default numbers
Hi Sy,
could You share the number of the application with us please? :-)
jauuu
Calvin
Old 26th March 2006, 01:32 PM   #6
SY's Avatar
US 20050147265
Inventor: Maarten Smits
Old 27th March 2006, 11:57 AM   #7
there is a problem inherently to the inverter technology. Since the membran and the stators are very conductive, the ESL do not work in constant charge but constant voltage mode.
As a result the charge on the membrane will change when it comes near to one stator. As we all know this means non-linear movement and increasing distortions. Especially at lower frequencies the change of charge and the distortions will increase.
This technology has its advantage regarding safety and should deliver more sound pressure at lower frequencies at given audio input voltage. But as always, nothing is for free. Distortions are the limit for such a system.
regards,capaciti
Old 27th March 2006, 12:21 PM   #8
Brian Beck's Avatar
I read the application, which appears to contain several little gaffes. I agree with Capaciti; this design does not appear to use constant charge operation. Furthermore, there is a claim of safety since high voltage AC is removed from the stator. But this design uses +/-3000VDC on the stators. The inventors placed a 10M resistor in series with each DC supply followed by a shunt 4nF cap to ground. While I doubt that the energy stored in these caps could injure or kill, I wouldn't want to touch a stator with my hand while another part of me is grounded. I doubt UL would approve.
Also, I think the use of concave inner stator surfaces is questionable on several grounds.
Brian
Old 27th March 2006, 12:23 PM   #9
Perhaps we can assume that the membrane does indeed have a necessarily low resistance but I am not sure that we can assume that the stators do too.....unless I have missed something.
Tim.
Old 27th March 2006, 01:09 PM   #10
regards,capaciti
If we would make a membrane resistance constant and low , and allow some current to flow through it , like in a conductor , wouldn't this decrese charge migration ?
Lukas.
Inverted vs non inverted what is the whole story...? Nordic Chip Amps 15 3rd December 2006 09:41 PM
noob question: inverted/non-inverted dieselpower Chip Amps 2 20th December 2004 09:19 PM
Inverted or non-inverted... that's the problem Faber Chip Amps 24 18th February 2004 06:44 AM
Circuit questions - Inverted vs non-inverted (again) alvinlim Chip Amps 4 1st July 2003 11:27 AM
Page generated in 0.09146 seconds (86.57% PHP - 13.43% MySQL) with 10 queries
