The ESL Build Thread - Page 16 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 29th August 2006, 01:45 AM   #151
BillH is offline BillH  United States
BillH's Avatar
Hi, all. The build is still alive!
I took some time off from posting to completely rebuild a pair of HV bias supplies. Rather than turn the thread into a long 'How to design and build a high voltage boost power supply', I'll try to keep it short.
First, some things I learned:
If the test meter doesn't show what is expected, check the meter.
My old Heathkit VTVM was having trouble reading AC with dirty switch contacts.
Digital VOMs don't like high voltage.
They break, luckily mine was cheap to replace.
If the test meter doesn't show what is expected, check the parts.
I fried a two mosfets and spent a few days trying to figure out what was wrong.
Keep a box of spare parts around even if your wife/roomate/signifigant other thinks it's crazy.
One of the parts vendors I've used for years with no problems messed up an order. No problem, I took some capacitors from a junk TV board and got pinhead jumpers from an old ISA computer board.
The picture shows one complete system. There's a 16.8VDC 300 ma wall transformer on the left. That feeds an Elliot Sound Products Project 38 'Signal Detecting Auto Power-On Unit'. It has only been changed to use a single speaker level input and added dropping resistors on the 9V relay that I had in the junkbox. The 'Power-On Unit' feeds unregulated DC to the next board, a DC chopper and voltage multiplier, when it detects speaker activity.
Old 29th August 2006, 02:28 AM   #152
BillH's Avatar
Here's a schematic of the DC chopper and voltage multiplier board. It has an LM555 astable multivibrator with a variable frequency of about 10KHz to 20KHz. The frequency determines the output voltage from the transformer. My prototype puts out 80V-660V RMS depending on frequency. Lower frequency=more voltage.
There's a couple of options built into the board that can be used if you wanted more output voltage. I didn't, but they could be helpful if anyone wanted to use this circuit with a transformer with a lower turns ratio. JP1 selects either 12V regulated or input voltage unregulated to the step-up transformer. Use the input voltage unregulated for more voltage. Use capacitor C17 for more voltage. 0.1uF(100nF) is a good starting point with the astable part values as shown. The values of C1 and C17 may need to be tweaked to resonate with a different transformer.
The X2-X10 pads are not used. They were there to tap the of the voltage multiplier for lower voltages, a remnant of an older design. I connected VSELECT to X10, the highest voltage tap and adjust the output voltage with R4 instead.
Old 29th August 2006, 02:40 AM   #153
BillH's Avatar
Here's a chart of the prototype's frequency, transformer output voltage, and supply current.
Old 5th September 2006, 12:02 AM   #154
BillH's Avatar
Here's a photo of the back of one of the ESLs with the back cover off.
On the left of the cover is a bank of series connected 6.8K resistors salvaged from my original crossover and behind it is a two-pole six-position switch that forms a variable high pass filter on the narrow stator sections. It will switch between no filter or from one to five series resistors. At first listen to the ESLs with no filter, the midrange seemed a bit too strong. The 6.8K resistors give a subtle adjustment and I'm using a string of three at the moment. The wide stator sections are running fullrange.
The automatic turn on-turn off board is in the middle. To its right you can see the speaker input. Behind the input, but hidden is a 2.5mm connector for DC in from a wall transformer and an LED pilot light to show when the high voltage supply is on. I haven't been shocked yet and the pilot light was a last minute addition to make sure I know when the high voltage is working.
The black and white wires with terminals on the free end will connect to the perforated stators.
Inside the ESL, the new high voltage power supply on the left. There are two boards of resistors near the middle that form a series resistance for amplifier protection. They form a 2 ohm, 20 watt non-inductive resistor. The audio step-up transformer is on the right.
Old 5th September 2006, 12:23 AM   #155
BillH's Avatar
And a photo of the back with everything closed up.
The ESLs at 43" high and 3-3/4" deep was an accident waiting to happen. It was only a matter of time until I bumped one of them or one of our dogs hooked one with a tail and down it went. The block sticking out the back is there to keep the ESL in an upright position.
It's about three pounds of weight cantilevered out 12". Very effective.
Old 5th September 2006, 02:00 AM   #156
BillH's Avatar
I've had a chance to listen to the pair together with woofers for the first time this weekend.
Short review:
I really like them. Voices sound lush, drums have a nice attack, and cymbals shimmer. It seems like I hear more detail in the music than I'm used to. Complex music is easier to listen to and I suffer no listening fatigue. After a while I found that I was listening to the music instead of listening to the speakers. The soundstage extends past the speakers and performers seem precisely positioned.
Long review: Everything above is true, but there's still room for improvement.
The ESLs don't like to have a wall behind them. The farther away they are from the wall, the better they sound. Too close and there's some serious comb filtering happening. 24" is too close, but that's about where I'd like them to be. I need to try some wall treatment behind them.
One of the ESLs has some leakage. When it was first turned on, I could hear arcing and a loud hiss from a small area. It's coming from the stator with the diaphragm glued to it. I've been able to partially fix it with small strips of paper between the front and back insulators and reducing the bias voltage. There's still a slight hiss that I can live with for now.
Efficiency is good. Certainly not like a dynamic driver, but my 100wpc amplifier drives them as loud as I want to listen to them.
High frequency dispersion is practically non-existant, typical of a flat-panel ESL. I thought that two 1-1/2" wide panel sections would help that, but physics wins again. It predicted dispersion dropping near 3000Hz. With careful aiming of the ESLs and precise recliner positioning, there's a 3"-4" front to back sweet spot, but what a spot!
I still haven't got a good crossover point between the ESLs and woofers. According to the frequency response of the ESLs, a 12Db/octave filter on the ESLs and a 24Db/octave filter on the woofers at 500Hz should give a smooth transition between drivers. It doesn't work so well. I'm using DSP software on a computer sound card to do the crossover now, so changes are easy to make. At the moment a 300Hz, 24Db/octave crossover sounds better, too high and voices start sounding wrong.
I think the woofers are the problem. They're transmission lines with 8" woofers that are lightly stuffed now and work with a lower crossover frequency, but there's too much midrange coming from the terminus at a 500Hz crossover point. I'll have to add more stuffing to get the bottom end in line and do some more listening.
Here is the setup. The ESLs still need grilles.
Old 5th September 2006, 03:04 PM   #157
Few is offline Few  United States
BillH: Very nice job with the construction. It certainly looks less "DIY" than many of the projects I've put together!
On the dispersion issue, perhaps I misunderstood, but I thought you mentioned you were running the wide panels full range. That would certainly cause the high frequencies to beam. I assumed you were going to send the high frequencies just to the narrow panels, and send low pass filtered signals to the wide panels. That would reduce the beaming effect. You could either run the narrow panels full range, or if their resonance frequency intrudes, high pass the signal first.
Sorry if I just misunderstood something...
Few
Old 11th September 2006, 05:48 PM   #158
BillH's Avatar
Hi, Few and thanks.
That was the plan, but it didn't work out. I wasn't able to get a high-cut filter that worked on the wide panels and just went with a low-cut filter on the narrow panels to adjust the midrange a bit. If anybody has an idea on how to make a high-cut filter for the wide panels, I'm very open to suggestions.
You did give me an idea, though. I want to try running only one wide and one narrow panel to see how it sounds and if it has any effect on the dispersion. I'll let you know.
I've got the grilles finished and still need to tweak the woofers and crossover point. It would be done by now, but I had to take a break from the ESLs to finish some painting in our house.
Old 11th September 2006, 07:54 PM   #159
Hi BillH-
Have you tried just inserting a resistor in series with the wide panels? Combined with the capacitance of the panel you get a first order low pass response. If the resistor is before the transformer it'll need to tolerate significant current, and if placed after the transformer there will be a big potential drop across it. I've put the resistor after the transformer (the high voltage side) and experienced no trouble, at least when playing at the prototype stage.
Few
Old 11th September 2006, 08:00 PM   #160
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
Send a message via Skype™ to Bazukaz
About resistors in HV filters :
just remember that resistors have max. operating voltage , beyound which their lifetime decreases a lot and distortion increases.
You can use several lower voltage resistors in series.Metal films are highly recommended.
My TABAQ Build Thread Consul Full Range 24 25th April 2016 11:04 PM
SE - Build Thread soundengine355 Solid State 6 27th June 2009 12:19 AM
aikido build thread- nate Tubes / Valves 1 27th February 2009 05:01 AM
My SE KT-88 Build thread athos56 Tubes / Valves 13 21st December 2008 06:16 AM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 01:15 AM
Copyright 1999-2017 diyAudio
