Transformer for esl without center tap - Page 2 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 1st March 2006, 06:47 PM   #11
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
Send a message via Skype™ to Bazukaz
Simple math:
If the input voltage is 100V , output Z = 4 ohms , P = 60W.
So, Vout=60/4=15 volts.
Turns ratio is 100/15 = 6.6
Not so good.
if P is lower , output V is lower too , and turns ratio is higher.
Search for old tube amp trannie , if you can get it.
For now i am building a headphone direct drive amp , maybe it will be able to drive small ESLs in low volumes - i will try if i succeed... a prototype works at 100V Rms output , but final project is targted to 400VRms.
Lukas
Old 1st March 2006, 10:42 PM   #12
Originally posted by Bazukaz
Simple math:
Not so good.
Lukas
There is something wrong with your math, 60 watts into 4 ohms is (60*4)^0.5 = 15.5 volts, very close in this case but this is the right calculation.
Old 2nd March 2006, 03:50 PM   #13
Bazukaz's Avatar
I agree.In my calculation , i get 15 V*A*Ohm units... Strange why the result is so close . Actually , the formula is P = U^2 / R
Center tapped transformer help Buzzy Parts 2 8th August 2008 10:35 AM
transformer with no center tap traw Parts 0 3rd June 2006 03:36 AM
Need Help With a True center tap Transformer catalina3899 Chip Amps 10 8th April 2006 09:40 AM
Transformer Center Tap dswiston Parts 2 4th February 2004 04:09 PM
Where can I get a 36-0-36V (center-tap) transformer? JDogCMS Parts 2 11th September 2003 08:11 PM
Copyright ©1999-2017 diyAudio
