| Planars & Exotics ESL's, planars, and alternative technologies |
Ive just had a thought It may be totally erroneous but here goes :-
Buy 2 cheapo piezo's @ 2.50 ea. (price of ksn 1038 clones in my local musical instrument store) .Wire one in series with a 100 ohm linear pot and wire it anti - phase to the first one .adjust pot for smoothest output (measure value and replace with fixed resistor) any mileage in this idea ?
heretics are sometimes right |
#2 |
For a lousy five bucks you aren't willing to do the experiment yourself and truly learn from a hands on experiience that begins with an idea? This is the DIY forum. Are you in the wrong line?
I am not picking on you. I am picking on your method.
I.Q.Test. Have you ever purchased a recreational snowmobile? |
#3 | |
I_F |
#4 |
Hey, No sweat
I probably will try it but at the moment Iam in the middle of building a set of speakers using ksn1165 and i just thought I,d share the Idea in case anyone had thought of using this Mechanical negative feedback idea before - at least theres no delay involved as in electronic feedback !
#5 |
I_forgot,
I thought that in theory of applying direct negative feedback to the output at a reduced volume would smooth the peaks and troughs and give a smoother output .As I said - IS THERE ANY MILEAGE IN IT . I put the Idea up to see if it stood up theoretically I am sure you bods probably Know why its a non runner!!
#6 | |
NO THERE IS NOT ! ![]() You are not using negative feedback and the the principle of linear superposition means the result will be the same as using one tweeter attenuated. In practise it will be worse due to inteference between the two tweeters. /sreten.
#7 |
Thanks Sreten ,
I had realised overnight that it would not work with program material - Ive been looking at too many response curves lately!
| fullrange piezos | el`Ol | Planars & Exotics | 6 | 24th May 2007 03:30 PM |
| fullrange piezos | el`Ol | Parts | 1 | 3rd May 2007 12:33 PM |
| Piezos in a Line Array | Mutley666 | Multi-Way | 4 | 3rd May 2006 05:47 PM |
| Page generated in 0.10565 seconds (79.04% PHP - 20.96% MySQL) with 10 queries |
