| Planars & Exotics ESL's, planars, and alternative technologies |
#21 |
Thanks for pointingout that this wont work as intened...
However, I should think that the nickel in the gap of a normal ribbon should serve to help complete the magnetic cicuit which could help the field uniformity? though, probably not enough to overcome the expense of lower efficiency. Why don't people build much narrower HF ribbons? I am thinking about making a ribbon super tweeter that is an eight inch by one inch or smaller in between only two comparatively huge magnets. Hoping to get high efficiency... Maybe even high enough to only have to pad down instead of use a transformer. How does adding a resister in series affect the sensitivity; ie, if i put a four ohm resister in series with a 100db speaker what is my final sensitivity? i supose it also depends on the resistance of the speaker which in the case of a ribbon will be small of course. I am hoping to jsut be able to pad down my tweeter to 89db. Thanks |
#22 |
You can get nickel foil from here.http://www.hpmetals.com/index.html
| Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate | lduarte1973 | Multi-Way | 3 | 16th June 2009 08:50 AM |
| Needed: transformer core materials cobalt nickel | arieknarie | Tubes / Valves | 0 | 27th February 2009 01:21 PM |
| I Need Nickel Iron Laminations and Bobbins ! | Nikolas Ojala | Swap Meet | 3 | 7th April 2008 03:57 PM |
| source of nickel + silicon steel laminations | beetel | Tubes / Valves | 1 | 22nd September 2007 06:29 AM |
| superalloy ( 78% nickel/2%cobalt) EI-66 with Furukawa ultimate wire. | tube-lover | Tubes / Valves | 1 | 22nd January 2006 03:35 PM |
| Page generated in 0.06828 seconds (69.62% PHP - 30.38% MySQL) with 11 queries |
