| Planars & Exotics ESL's, planars, and alternative technologies |
Banned
I just picked up a neat old pair of Spectra 3's and notice they use some sort of a delay line where the inside panels that run 'full range' or have the treble reponse and are delayed from the the two outside lower range panels. I've only had them hooked up for a few hours and am already getting curious in knowing more about this configuration. The speakers actually seem to be fairly full range with out the crappy little 10" bass driver - Maybe down into the low 40's strong. What I'm wondering is how is this delay done? What I planned on doing was biamping the panels and splitting the signal between the fullrange ond low range panels. Without measuring it sounds like around 400 cycles.
Has anyone here biamped to the delayed panel with the Spectra 3 or 4 Acoustats? (not the 10" woofer)??? Did you keep the delay intact? How are they wired for the delay? The speakers sound pretty good stock, fast like my horns but a bit more coherant. Much better than the 1+1's, Innersounds or Martin Logans I've had - They reproduce the upper bass and low midrange very well - Sure suck some power! I'm used to 100 db+ sensitivity.. I'm just thinking about biamping and would enjoy any feedback. Thanks
#2 |
Banned
I took them apart - the only way to biamp them requires another pair of Medallion transformer per speaker. Seeing they are ultra expensive I don't think it's worth the expense to do this - just use a bigger amp........
#3 |
Spectra "delay lines" are not delay lines at all. Only the QUAD 63 and it's new children use delay lines.
The Spectra solution is very simple. The inner panel is driven full reange - with the outer panel(s) driven through high value resistor(s) to roll off their trable response - adding their energy to the lower frequencies. I have a pair of Spectra 11's that I use without the BS woofer - they sound really graet - especially for the $200 I paid for them! Allen |
#4 | |
Banned
#5 |
Hi Allen
Are you running the Spectra 11 transformer full range also, or using lower frequency cut off than factory to your sub? Regards Grantn |
#6 | |
Still I agree that Quad made an attempt at a classic lumped-parameter delay line while Acoustat took the more traditional crossover approach.
Brian |
#7 |
Grant,
>Are you running the Spectra 11 transformer full range< Yes - even though Andy Svabo warms against it. > or using lower frequency cut off than factory to your sub?< Most of the time I don't even use a sub, but even when I do the ESL's don't get rolled off. Allen < |
| Amp suggestions for Acoustat Spectra 22's? | JmanGTA | Planars & Exotics | 8 | 23rd July 2008 05:40 PM |
| Acoustat 1+1 from Spectra 1100? | noelm | Planars & Exotics | 2 | 19th February 2007 06:52 PM |
| Group delay of a transmission line? | 454Casull | Multi-Way | 4 | 8th July 2004 03:34 AM |
| Help for Acoustat Spectra 33 | Oz_Audio | Multi-Way | 7 | 18th October 2002 09:01 PM |
| Page generated in 0.10135 seconds (84.47% PHP - 15.53% MySQL) with 10 queries |
