Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 29th January 2006, 04:26 AM   #11
I'm no expert on electrostatics, but I have read some articles on building them.
If they are rear speakers, I assume these would not be going below 150 Hz or so?
Because the electrostatic diaphragm is stretched tight, I don't think the electrostatics require a whole lot of space behind them to work properly. In regular electrodynamic speakers, the speakers with the softest suspensions have the greatest Vas. With the diaphragm stretched tightly like an electrostatic has, I would think the Vas would be truly negligible.
The wavelength of 20,000 Hz-the shortest wavelength you would be concerned with-is 0.675 inches. An eighth of that would be 0.08 inches. It seems to me all you would have to do is make some kind of round structure with a diameter 0.16 inches less than the inside stator diameter, stick it in the middle of the speaker, and you should be all right.
Don't hold me to this, because I've never done it, but I really don't think a small electrostatic requires any appreciable amount of space behind it to operate properly.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 25th February 2006, 09:14 PM   #12
bear's Avatar
the problem is not what has been mentioned thus far.
the problem is how to curve a mylar diaphragm around a cylinder and support it at the same time??
sand would not likely be a good thing in the center, since it will look rather reflective at higher freqs, and reduce the volume behind the diaphragm, plus be heavy as all get out.
try a segmented esl, with a number of faces, think octogon, or higher frequency shape... easier to make, and if it sux, you have a bunch of nice ESL cells that you can use otherwise...
_-_-bear
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
bracket for cylinder shaped riotubes Parts 2 16th June 2007 12:50 PM
Make sonotube from old propane cylinder? Circlotron Multi-Way 19 26th July 2004 03:58 AM
my DIY Cylinder LS and Bailey TLs malc_hurn Multi-Way 0 3rd January 2004 06:18 AM
Page generated in 0.06424 seconds (71.73% PHP - 28.27% MySQL) with 10 queries
