| Planars & Exotics ESL's, planars, and alternative technologies |
#2 |
Looks very nicely done! How about some details?
#3 |
it is 150cm long and 2cm wide.The aluminium is 4 my glued to 15 my paper.It is korugaited along the 150cm not on the 2 cm.And then it is closed ind the sides.crossover point 200hz.
Andre´ Jensen |
#4 |
her is a closer look at the ribbon
#5 |
Finished my first DIY Ribbon - look under "Lautsprecher" at www.michaelgaedtke.de
Michael |
#6 |
Very nice looking link there michael along with clear pictures...
i wish i could understand german... |
#7 |
Here comes the missing part I of my DIY Ribbon article - look at "Ribbon I" under "Lautsprecher" at http://www.michaelgaedtke.de/.
Michael |
#8 |
Here I show how I constructed transformers for my ribbons:
http://www.michaelgaedtke.de/Ribbon_3.htm
Michael |
#9 |
Hello again,
from a friend I borrowed a gaussmeter which measures the strength of magnetic fields with a probe small enough to be positioned in the gap of my ribbon speakers. Here are my findings: Fortunately the field is a) highly concentrated in the gap b) linear across the length of the gap; linear part begins after half of first magnet block (some 10 mm) so that total homogeneous field ist just one neodym block shorter than magnet row (9 out of 10) c) as far as the old gauge is correct field is strong at some 0,5 Tesla (5000 Gauss) in the middle of a 12 mm wide gap between double rows of magnets - see foto. By the way: I also tested if the field is influenced by the addition of iron pieces across the ends of the frame to close the magnetic flux in the rear of the ribbon. Varnhagen seems to be right in his finding that this doesn't make much of a difference in efficiency - I could hardly see a deflection of the meter pin.
Michael |
#10 |
| To ESL or to Ribbon? | PhaseLockLoopy | Planars & Exotics | 83 | 5th August 2011 01:01 AM |
| DIY ribbon mic | rafafredd | Analogue Source | 6 | 14th September 2009 10:37 AM |
| Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate | lduarte1973 | Multi-Way | 3 | 16th June 2009 09:50 AM |
| ESL, Ribbon THD | Mor den Siur | Planars & Exotics | 26 | 2nd March 2009 11:09 PM |
| to ESL or to ribbon? | lekguan | Planars & Exotics | 3 | 4th December 2008 03:53 PM |
| Page generated in 0.10405 seconds (77.50% PHP - 22.50% MySQL) with 11 queries |
