Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 31st May 2006, 06:32 PM   #21
amt is offline amt  United States
Default and the text..
Couldnt translate this since it was graphical and I dont have OCR software.
amt
Old 1st June 2006, 06:40 PM   #22
Kensai is offline Kensai  United States
Send a message via AIM to Kensai
Neo3 in dipole for sure. Couldn't stand the sound of the things with their back cups still on. Of course, you can't cross them over as low without them, but you seem to be using them for supertweeter duty so it will absolutely not be a problem.
Kensai
Old 1st June 2006, 07:09 PM   #23
Thanks Kensai, you are the second person who has recomended dipole so it will be done. I asked this because I have heard of some problems with dipole tweeters however those were specific cases.
In addition I have read that if M-T are dipole then W should be dipole. I really dont want to do this though, so is an ML-TQWT with a rear firing port going to bring the monopole behavior of a TL closer to the dipole nature of the M-T. My main concern is the figure 8 radiation of dipole and its reduced energy bouncing off my concrete walls from ~700hz and up while there is a spherical wavefront from 700hz down. I suppose this would cause alot of low frequency reflections off the wall muddying up this range. These two 8's "should" give me an f3 in the mid 20's in a TL w/o room gain(orginal goal), what size of baffle would I need to get an f3 of ~40hz in dipole? I will be building a sub for HT however I would like the mains to be able to reproduce the full audio spectrum on their own.
Old 2nd June 2006, 12:14 PM   #24
...if M-T.... ...so is an ML-TQWT...
Does M-T = Mid-Tweet? and what does ML-TQWT mean?
on another note you could (actively) XO the BG 8 @ 700 with little consequence. just my $0.02
Tony
Old 2nd June 2006, 09:59 PM   #25
Yes M-T is mid-tweet, W is woofer
ML-TQWT = Mass loaded- Tapered Quarter-wave tube.
aka type of Transmission Line.
There will be no biamping, I know it will simplify my project however I will not buy a bunch of amps retail and do not have the time or experience to build them, now anyways.
Old 5th June 2006, 04:07 PM   #26
any idea how the BG would sound "screwed" to the front of an 11 " high, 22" wide baffle (MTM[MBGM or W/BG/W!])
Old 21st January 2007, 12:32 AM   #27
Ang is offline Ang  United States
Hi - I'm contemplating a similar 2-woofer design. Has the bass integration worked out well for you and how long is your tl? Thanks.
Old 21st January 2007, 02:55 AM   #28
Actually with my senior year of Mechanical Engineering studies I have not completed the speakers, I can say however that the design has been adjusted to be full dipole. With this new plan I will now use a 15" Dayton IB in a 22" U-frame for bass and a radiused baffle for the two daytons. See pic
Old 13th April 2009, 08:28 AM   #29
Default Build with B&G Neo 8
Hi, I'm new here, Building a small 5.1 with the B&G Neo 8's. Thanks for the info on the XO's. Was curious how your build turned out. I'm just getting started, Still waiting on the speakers to come...lol Using 4 1/2 inch 4 ohm Boston Acoustics to fill in my bottom end down to 55 Hz. Thanks guys for your pioneering work.
FS-16 Dayton Pt 2 Planar tweeters Badge Swap Meet 0 4th December 2007 08:26 PM
MCM 55-1170 or Dayton classic 6.5"(295-305) ? percy Multi-Way 2 21st July 2007 12:27 AM
FS: 15-inch Dayton Classic IIs jmikes Swap Meet 0 12th March 2007 01:16 PM
dayton 10" classic woofers for PA... nerd of nerds Multi-Way 13 29th May 2006 02:24 AM
dayton pt2 planar tweeter huj69 Planars & Exotics 8 22nd December 2001 03:25 AM
Page generated in 0.09278 seconds (78.89% PHP - 21.11% MySQL) with 11 queries
