Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 28th November 2005, 04:41 AM   #1
gavinson's Avatar
Default Behringer 24/96 vs BSS vs DBX Studio Drive
Crossing a dipole ribbon with a monopole bass at 300Hz. Any thoughts on the most effective electronic crossover. Need also notch filter and balanced inputs.
I am not so familiar with the innards of the BSS or the Behringer.
My Ribbon Project
Old 28th November 2005, 08:33 PM   #2
Hi gavinson,
i use the dcx 2496 and i can tell you its an amazing tool. You will never miss the money you spent for.
6 channels, balanced in- and outputs. You can "notch" at each fequency you want with different damping modes.The best feature is the memory. You just save different setups and you are able to compare the sound differences within seconds.
I use the dcx for my ESL+Dipolesubs. The dcx show a noticable noise level in standby and sometimes i get the impression that the dcx slightly modifies the original signal. But nothing is for free.The advantages compensate for that and this crossover is far better than any passive solution.
BTW:This is an amazing ribbon !! I can imagine that it sounds breathtaking
regards, capaciti
Old 29th November 2005, 12:46 AM   #3
gavinson's Avatar
Capaciti,
I am sometimes "thick-headed". Years ago we used DBX equipment to restore dynamic range to recorded music, and I found DBX equipment to be as solid as it gets. So, my natural inclination is to move back to DBX equipment now that I need this electronic crossover. I know a lot of people use the 2496 and it does interest me. It's less expensive than the DBX, which I can get off eBay for under $400. A new 2496 can be had for $250. I'd sure like to know more about a direct comparison between them (I know there are people on this forum that can help me).
May I ask, what do you mean by "slightly modifies" the signal? How much effect does that have? How pronounced is the "noise level" you described?
Thanks for the compliment on the ribbons, I have really enjoyed having them back.
My Ribbon Project
Old 29th November 2005, 12:09 PM   #4
Hi gavinson,
i try to explain slightly modified:
imagine the sound reproduction of a single hit to a triangle. Listening with my ESL you are able to hear that the "colour" of the triangle sound changes constantly from the hit to silence.
With the dcx the time to silence is reduced and in addition the colours of the triangle sound different. It appears as if the triangle is made out of different alloy.
I don't use the digital inputs, but analog since the dcx is between the pre-and poweramp. Maybe A/D-D/A-converting compromises quality.
The noise level is about double the loudness of standard analog active filter systems.
capaciti
Old 29th November 2005, 01:04 PM   #5
Why is there a spike in each of the graphs at about 10kHz? Is there something in the testing procedure causing this?
Old 29th November 2005, 09:05 PM   #6
gavinson's Avatar
Hello ctviggen,
I am not exactly sure what you ar seeing. I think you are talking about some impulse response plots. They would be measured at 1K, in milliseconds. I could be mistaken. When I get home, I'll have to look and verify that.
Regards...
My Ribbon Project
Old 29th November 2005, 09:24 PM   #7
slowmotion's Avatar
Originally posted by Capaciti
Hi gavinson,
capaciti
I use horns and I don't have any noise from my dcx 2496.
cheers
Old 1st December 2005, 07:22 AM   #8
Hi slowmotion,
thats astonishing. Using horns the noise level should be ampified further due to higher sensitivity.
Maybe my dcx is a worse one out of serie production, but i got feedback regarding noticable noise level from others as well.
Do you run it with digital input ? Should lower the noise level.
capaciti
Old 1st December 2005, 08:05 AM   #9
Coolin is offline Coolin  Netherlands
Coolin's Avatar
I dont have noise iether on my dcx and horns.
I beleave it went away when i improved the power supply.
It wasnt bad at all but now its silent
Used beads and quality caps
Im using digital in
Old 1st December 2005, 08:54 AM   #10
slowmotion's Avatar
I'm using analog in, no noise.
It's important to get the levels right,
and preferebly volumecontrols between the crossover and the poweramps.
cheers
FS: Hitachi Router and Terk outdoor HD antenna, BD-Rom drive, Xbox HD Drive and more. Dougie085 Swap Meet 0 3rd May 2008 08:31 PM
mix current drive with voltage drive at LF? capslock Multi-Way 0 27th April 2006 11:17 AM
behringer dcx + passive preamp + studio pa leifislive Digital Line Level 3 3rd March 2004 09:28 AM
Idler wheel drive vs. Belt-drive mig-ru Analogue Source 4 3rd December 2003 01:06 AM
Computer Question-Any Problems Transferring Office 97 From D Drive to C Drive kelticwizard Everything Else 12 22nd January 2003 04:34 AM
Page generated in 0.11004 seconds (77.94% PHP - 22.06% MySQL) with 10 queries
