Sealed ESL Design for DIYers - Page 3 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 7th November 2002, 04:48 PM   #21
phishead8's Avatar
I knew that SF6 was a good dielectric gas, but I thought that it was poisonous or something. Its good to know that it's safe stuff. Is it hard to come by?
-Dan
Old 7th November 2002, 04:57 PM   #22
SY's Avatar
Absolutely non-toxic (hey, I was *breathing* the stuff!), though if you do arc in it, it can produce low levels of fluorine which is toxic.
Easy to get- our local gas cylinder suppliers have it. If you've got an Air Products distributor nearby, they're a good source.
Old 7th November 2002, 05:28 PM   #23
a cheap transformer won't be rated for 5kV, it'll be rated for 2kV or something.
Read the ESL cookbook, he discusses transformer selection quite a bit. The published ratings aren't the ratings you are looking for. The voltage you are quoting is peak to peak, the rated voltages are usually RMS, for example.
== John ==
Old 7th November 2002, 08:07 PM   #24
Hey, i've got a question for the ESL elite: if you use a step up transformer to increase voltage to drive an ESl and you step down voltage from a tube amp to drive a speaker, why can't one drive an ESL directly from the output of a tube amp before the output transformer? or, could one consolidate both transformer ratios and use only one transformer?
Old 7th November 2002, 08:10 PM   #25
SY's Avatar
Not enough voltage in most tube amps; you want to swing a couple of kilovolts, not the puny 200-400 volts of conventional tubes.
A purpose-built amp having an output transformer with, say, a 1 to 5 primary to secondary ratio might do the trick. I'm unaware of anyone making such a transformer, though.
Old 7th November 2002, 08:16 PM   #26
It's been done, try a web search for OTL and ESL.
Here's one circuit, although this is from surfing and not personal experience. Direct Drive OTL ESL amp
== John ==
Old 7th November 2002, 08:51 PM   #27
diyAudio Senior Member
fdegrove's Avatar
Default DIRECT ESL.
You can also play it local here:
Tube amp and electrostatic speakers.
Frank
Hi-End Sealed MTM Bookshelf Design? treytexag Multi-Way 35 15th July 2008 07:34 PM
Should I Try A DIY 12 or 15" Sealed Design?? Fore Subwoofers 34 12th September 2007 01:37 AM
3 way sealed loudspeaker design dih1118 Multi-Way 23 16th September 2003 04:59 AM
Copyright 1999-2017 diyAudio
