| Planars & Exotics ESL's, planars, and alternative technologies |
5VDC in 1500VAC out- $5
See here: http://tinyurl.com/8q9uo Manual here: http://tinyurl.com/9johs Easily multiplied to 3 kVDC or higher with a few diodes and capacitors. I_F |
#2 |
Great find.
The CCFL inverter in general seem to be a standard DC to AC converter. Even though they are made for a fluorescent lamp, there isn't any special starting voltage or current produced, just high voltage AC. Small, cheap and readily available from many online sources. The inverter you linked even has provision for soft on-off switching. Here's a pdf file describing CCFL inverter design. |
#3 |
Interesting, looks like one of those would work just fine, 1500VDC out is enough.
#4 |
The output is AC. You still need to rectify it and don't forget the big series resistance.
Use one HV diode, a small HV capacitor (try 100 pF to 1 nF), and 10M-100M resistor in series with the output. I_F |
#5 |
well guess i messed that one up.
#6 |
Very simple. Any HV diode rated for 5 kV should be OK.
I_F |
#7 |
Great thanks.
#8 |
I forgot...
That circuit will provide about 2100 VDC. I_F |
#9 |
OK, I got stupid ?.... I searched on mouser for 5K diode, no 5K diode but I get 5K rectifier, is rectifier what I want .
#10 |
just connct several 1kV-Diodes in series, eg. 1N400x jauu Calvin |
| Safe use of unknown small signal transistors | mashaffer | Parts | 8 | 29th July 2008 01:35 AM |
| in a CLC input supply: is it safe to use... | jarthel | Power Supplies | 2 | 9th July 2007 12:39 AM |
| Fail Safe Power Supply | Allen Newby | Pass Labs | 38 | 10th June 2007 08:14 PM |
| Safe to increase bias on factory Aleph 30's? | hifimaker | Pass Labs | 5 | 18th January 2005 09:18 PM |
| Page generated in 0.10399 seconds (75.51% PHP - 24.49% MySQL) with 11 queries |
